Hi all,
I am at the stage where I can't drive my car with out it air flow cutting. eg. AFM picks up too much air and the ECU cuts.
I have a KKR480, very high flowing 3" exhaust, FMIC, SAFCII ect.
the stock actuator is 10psi and I am hitting air flow cut at about 5500rpm even on 10psi.
I don't really have the money to go full after market management because; PowerFC $1550 + $1000 for tune. Its actually cheaper to get a Link or Microtech.
I have been looking at some remapped ECUs on ebay but I really dont trust those because you can never tell what they have exactly done to the tune, eg the car they tuned it on could be nothing like mine.
Does any one know of a cheap way to remove this bloody air flow cut.. its really anoyying the hell out of me.
Also this is a full on ECU CUT not R&R, I will make a video later to prove.
some people call it boost cut but its not techniclly a boost cut as the ECU doesn't have a pressure sensor, its triggured by the ECU picking up too much air or a spike in air flow.
https://www.sau.com.au/forums/topic/193815-removing-air-flow-cut-rb25-r33/
I think its because you afm is at maximum voltage and cant read any more airflow, and hence cant meter fuel delivery from that point onwards. Thats why it cuts out, because from there onwards will become lean. Theres no way around it apart from bigger afm and aftermarket ecu.
the RB25 AFM is good for 240 rwkw kw... i highly doubt he's making that sort of power atm with a stock ecu.
What you'll find is that the ECu is cutting fuel. you need to either get an aftermarket ecu or get an RB20 ecu and remap that which is the cheapoer option (i have one of these)
yeah that is rich and retard. different people think it is different things. i had that on my r33. the cheapest option is to get a remapped ecu off ebay. if you go this way get it dyno'd straight away to check the AFR's. if they are lean then get a safc or something like that. the other option is to go a emanage ultimate. then you can remove the afm altogether if you want (with the addition of a map sensor). the emanage will be a cheaper option than a pfc and will give you about the same results if you go to a tuner that knows what they are doing (which is the same with a pfc. the quality of the tune more depends on the tuner than the ecu)
yeah 1k tune thats nuts
it would want proof every single cell was changed from the stock maps
$400 seems much more reasonalbe
and they are $1000 on ebay now a days the demand seems to have dropped off
ive seen two from memory go for around $1000 on ebay
No,
I have watched ebay for about the last 6 months and the cheapest one went for $1300 with out a hand controller.
The ECR33 Power FC are rare unless you want to pay $1500.
Its actually cheaper to buy a microtech and I would much prefer a microtech LTX12s over a PFC.
I live in Tasmania and don't trust any of the tuners here, I would prefer to boat my car to the mainland but year I was quoted $3000 for a Power FC installed and tuned from pritty much the only dyno tuner around here.
Its not R&R I don't care what any one says... Rich and retard is only about 4 degrease retarded and maybe between 10-11 AFRs. This compleatly cuts off.. eg no ignition what so ever... like the engine completely cuts there is no engine noise nothing. My car pings and when it pings the car R&Rs which feels like you have droped a couple of pounds of boost and thats all.
Also I already have a SAFCII and it hits 100% AFM at 5500rpm. I don't know if thats the true maximum though or just what the SAFC regards as max voltage.
Also E-Manage wont do any thing about AFM max or the cut, even with a map sensor because the E-manage translates the map sensor signal into a stock AFM signal so there for you might as well have an AFM any way because the signal can only reach so many volts.
Edited by Finny
Thats why people upgrade the afm to one that reaches maximum voltage at a higher airflow than stock. If you run a map sensor on an emanage you can change the scale of the maps to avoid running out of load points.
I had the same cut thinng happen to me a couple of weeks after i purchased my r33, removed the wategate actuator pipe and forgot to re-connect it. As soon as I went flat out, I went from pinned to the seat to nearly head butting the windscreen when the turbo boost went to god knows what, and maxxed the air flow meter.
the safc can be used to trick the ecu that the afm isnt reacing the voltage that it actually is, so it wont hit fuel cut.
the thing is, the ecu has 2 spots that ive noticed the boost cut hits. 4200 and 5500. ive maxed out both points with my turbo. what ive logged on my emanage is:
R&R starts to creep in at 3800rpm @ 3.8v. at
4200 boost cut hits at around 4.7v,
5500 it hits again at around 5v (afm maxed out as it only reaches 5.1 volts).
the emanage has a afm clamp setting, so i can tune all of these in with no worries. the safc needs to be put on a dyno with the correction values wacked in. just get it re-tuned and tell them thats whats happening.
heres a print screen of my log files:
heres where r&r starts coming in:
4500 fuel cut:
5500 fuel cut:
i hope it makes sence.
Ummm you do realize what a voltage clamp does....
I had a turbo smart fuel cut defender installed in my car when I brought it but I removed it.
This is why.
say you clamp at 4.7V so it doesn't cut
Say AFM reads 5.5V worth of air. ECU sees 4.7V.
Thats going to make it run very very lean and at those revs I wouldn't be surprised if pistons melted.
The way I know how to fix it for sure with out aftermaket ECU is this. get say 550cc injectors then run -33% fuel on your safc.
When AFM reads 5V it -33% so tells ECU 3.35V. Car doesn't run lean because injectors are bigger and there is no cut but AFM will max.
To fix AFM max run a 33% AFM bypass then you can remove the SAFC adjustments and the car will then max AFM and boost cut 33% later.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
