Hi....
Ive recently got an R32 GTR and was wondering if you guys notice a dramatic different in the power on say a 30 degree day vs a really cold night...
On a hot day it seems very sluggish in comparison....
How much power would you estimate is lost on a very hot day vs a cold night...
Thanks
Ashley
https://www.sau.com.au/forums/topic/193965-power-lost-on-hot-days/
HEAT SOAK!
Yeah it makes quite a bit of difference for me, I can normally bang in just under a bar of pressure on a cold night, but I won't see past ten PSI on a hot day...
Get some Cold Air Induction and it should do better :rofl:
i think it was a reduction in power of around 1-2% for every 5 degrees the inlet temp goes up. but don't quote me
the main thing you'll notice in super cold weather is sharper throttle response and more low to midrange torque. in fact, the engine is more likely to suffer pre-ignition in really really cold conditions as the charge density at the point of peak torque will be much higher than usual (MAF based ECUs account for this though, and trim the spark advance accordingly)
My understanding is that air is more dense on a cold day there for a better quality of air so ur A/F ratio's are more stable resulting in more power, On a hot day the density reduces causing a loss of power. Don't quote me thogh i could be wrong.
FWIW, here's a definition of heat soak from here. This is why you use a turbo timer, it has nothing to do with loosing power on a hot day.
"When the engine is switched OFF, the cooling system becomes inactive and the residual heat in the engine from the block, head and exhaust manifold are transferred to the coolant and other engine components. The engine temperature actually increases after a hot engine shutdown. This is called 'afterboil' or 'heat soak' and can be damaging to engine life."
No, the heat soak I meant was not getting enough cool air flow to the air intake...
You're talking about something different...
In 32 GTRs the air intakes are tucked pretty high up without a snorkel, so they can heat soak pretty well... the hotter the air, the less dense it is, so the less air that can fit into the cylinders... And without proper cold air induction, it sucks in all the hot air from the engines radiant heat...
And i dunno about you, but I use a turbo timer for the TURBO to cool down, it's not called an engine timer now is it? :rofl:
Very close, the air is more dense on a cold day, so the engine management adds more fuel to maintain the correct A/F ratio, and you make more power because you're burning more fuel. And vice verca so less power on a hot day.
I've never heard that referred to as heat soak before, but maybe i need to get out more. Google for heat soak and you'll see what i mean.
My stock 32 GTR has a factory snorkel....so it doesnt pull any air from the engine bay YMMV.
You're being a bit to literal :-)
Heat soak refers to what happens to the intercooler, i.e when the intercooler cant cool the air enough any more because its aluminum fins are heat soaked with well heat.. typically happens at traffic lights where the car can take on a shitload of heat.
The CAI system can also take on this but typically refers to the SMIC.. thats why a FMIC is alot better as the air charge is cooled much more efficently. hence why I bought the screwball thing
Edited by DECIM8
Heat soak is this, heat soak is that, nooo heat soak is this.
My goodness. Heat soak can mean heat soak on anything. It is as it states, soaking up heat. It doesn't have to be the pod or the motor or the intercooler. Heat soak can occur on a glass bottle in the sun, heck sponges suffer heat soak in hot water.
The terms should of been mentioned "heat soak of the _____".
Edited by KeyMaker
BINGO!
The basic idea of an engine is to ignite an air/fuel mixture and produce power. The more air we can get into a motor, the more fuel we can add to it, the more air/fuel mixture the more power we make. When temperatures rise air becomes less dense (less air in any given space), obiviously when temp decreases air becomes more dense (more air in a given space). Thats why on cold nights (when the car effectivly get more air) we get more power, and on hot days (car effectivly gets less air) we lose power.
:ph34r:
Depends on setup. When my R was stock, it felt like 25% lol... serious
Hence, the usefulness of EBC's
i try to keep away from the whole 'boosting' thing on a hot day
I never like this idea. Performance is total. What if it was 390 on a well planed track day? Would you baby your car? Thats for aftermarket (or PFC) knock sensors are for (not to mention human ears) I reckon the idea's to tweak your inlet temp correction to counter hot days. End results are end results, anything you can make compared to the guy next to you, is a profit smile.gif
this is where high quality coolers etc come into their own and shitty ebay bar and plate coolers start to sap power.
Trent, wasn't there a time, when bar and plate coolers where deemed superior to tube and fin? AVO's 1000hp coolers are still bar and plate... as are upper echelon HKS IC's i believe.
"When the engine..."
For the purposes of the performance arena, i think "heat soak" refers to when the devices that are meant to move heat from intake air -> IC -> ambient air work in the opposite. This is noticeable in stand still traffic, where a IC can introduce ambient temps BACK into the IC -> intake air. This applies of course to intake piping and plenum's etc. F_ck Google.
Meh to stock, 400rwkw+ deems AM pods and a proper CAI necessary for street application (im sounding like a c_nt tonight, must the the multiple personalities) :(
: To answer your original question, i think R's suffer from heat soak more then others, due to the surface area of all the piping. Twin turbos, twin intakes, twin filers, twin manifolds etc. My R when stock felt like a dash mounted marshmallow after a stand still period. Proper CAI's, bonnet vents etc help, but even after you have tweaked all your inlet temp correction values, you have to accept more heat means less power. You can imagine then why 5mins cruising in 5th at 80km/h in 50 weather has such a profound effect on throttle response and mid range (due to the ignition advance the ECU winds into (or should) in those conditions)
read into it, what you will loler'NZ-bungie jump
Edited by GeeTR
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
