  • 4 weeks later...
Did anyone find this screen under diagnostics? What is it?
Tom
Looks like GPS diagnostic data to me - HDOP/GDOP are data values related to predicted GPS error, I'm guessing that the next 3 lines are the signal strengths of the satellites currently in view. The next lot of data looks to be related to an inertial gyro - guess the V35 sat nav must use this as a backup/x-check for the gps data. This quite common for built-in systems, the gyro data means you don't lose your position in a long tunnel and improves accuracy in a city with lots of tall building which can confuse the GPS receiver.
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3570562
  • 3 weeks later...
i am anxiously checking this thread for the solution
pls somebody god help you
There may be a solution. I have made contat with a Russian company that has done the conversion from Jap to Russian. They believe they can do the conversion but will need min customers 20-30 to make it worth while. Then there needs to be someone who can install the firmware. One option send the units (nay above glovebox) to Russia or better is to find a local comany who can work on the units.
Second step is to work out how we get local maps?
The company I have spoken to is http://www.xanavi.ru/cnt.shtml, You can see some of the converted windows on their web site.
A fair way to go but it is a start.
I have had about 5 people so far say they would do it. >_<
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3605147
In regard to the Jap to English ....just as an exercise I have had a play at translating the russian from the russian web site screen shots and here it is. I know I could have gone to the us english site etc but I wanted to try.
A bit obscure I know but ....hey someone may be interested.
See attached file :v35ruskitoengli.doc
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3613009
People,
you may want to check that thread:
http://www.skylinesaustralia.com/forums/M3....html&st=80
I will re-post my message here :
Ok,
guys from Moscow approached me today. They have a "demo" version ready, now they need a brave person in Perth who's got a car DVD based Xanai unit (M35 Stagea or Skyline up to 2005). This gotta be a 2-step proceess:
1) we need to determine the exact version of that unit's unit firmaware and let the guys know
2) they will porvide is with demo (partially translated) version and with original firmware, if that person decides to load the original firmware.
At this stage they are not willing to distribute the demo around the globe :D
screen dumps attached.
Edited by And
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3623155
can someone send me a dump of the japanese firmware? I might be able to translate it to english. I used to do it for a living, recoding japanese software to english.
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3623158
  • 2 months later...
any updates?
The conversion is being worked on at the moment but they are setting up a distributor system for it so they will be paid a fair price for the conversions. The metod of conversion is by installing a disc in the DVD rom and updating the software so the potential for them to do a lot of work and get no return is very real.
I would say by June/July we will have a system set up and a fair price. As soon as I have some more definive dates and costs I will post it up.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/2/#findComment-3772901
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
