The conversion is still being worked on and I was told last week that we should see it around September. I am keeping every thing crossed in the hope of getting it sooner but stay tuned....
Cheers
Andy
I thought you said it will be around in June ? is that still possible ?
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3835987
June was the expected date but it is taking a bit longer than anticipated. The english conversion is not the hard part, it is protecting them selves against people doing multiple installs and not getting their fair return for all their work. They are creating a dealer pack that will allow them to control the number of installations from each disc.
I will keep you posted if there is any news of an earlier release. Trust me, I want the conversion as much as the rest of the M35 and V35 owners.
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3836659
would still be a long wait, as the dates have now been pushed to September... so check back this thread in a few months time :thumbsup:
In the meantime, does the Navigation DVD ROM unit controls what comes out on the trip computer screen display?
Was wondering if chucking in a USDM G35 one would display some US specific trip computer screen?
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3855514
from what I understand of this system, it would change the look of the information coming out. whilst it is all drawn from the same source it is the programmimg of the DVD rom that determines what info you see.
Cheers
Andy
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3855885
Does that make it worthwhile sourcing a G35 DVD-ROM unit? What are the differences?
no it does not. if all you want is the info in english - go for it. bear in mind there are 8 different boxes that go in these cars. if you know which one you have - try. bear in mind that they (USDM) are a DIFFERENT car than what you haev so you will lose a few features - TV being one of them.
rianto,
not worth your while. it will affect EVERYTHING on yours.
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3856083
We just can't win, can we!?
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3856111
nope. I'm looking at fixing the radio display though so it works correctly. forget trying a USDM radio - thats different too.
Hi Chris
Do you know how to change the radio frequency for the "traffic" preset station? looks like )))))
Cheers
Andy
PS. I know I still have a job to do for you. I will be able to do it soon
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3859486
Hey Guys,
I am new to the forum, I am Australian but living in Singapore.
I am on the verge of buying a V36 up here there are about 10 on the road already and have been trying hard to figure out this software problem, lots of searching the net lead me to this graet forum.
Can I just confirm that the conversion will work on the V36?
Cheers
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3873550
Final verdict is not for me to say but looking at how V36 screen is different to V35, I would likely be confident to say it won't work...
unless the company do another version for V36...
So in Singapore there was no infiniti dealership network? And the Nissan there didn't officially import a local version of this car?
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3873562
Infinti does not exisit in SE Asia at all and you are correct, lots of Nissans on the road but no Skylines as Nissan did not bring it in.They bring in the 350Z Fairlady and possibly the GTR R35. Not great if you want a G37.
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3873972
how can they restrict the use of a dvd upgrading firmware..unless they make it so you have to hook up some a specialised piece of hardware for it to work
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3884131
dunno. I can't see that happening myself. probably why they are hesitant to let the code loose.
I know that with the earlier VDO/Blau nav discs you could copy them as many times as you liked. the later ones wont copy with out special software and that is only a torrent away anyway.
I exhausted most of my japanese options on this. I have yet to apply a consult 3 to one of these cars (and for the $9k ask I probably wont for a fair while.) yet. if I can convince a dealer here in brisbane to let me connect a car to theirs then I'll have a bit of a play. the aftermarket ones will not access teh earlier J2534 cars but it will access the later CAN based ones. that was a $7600 ask btw.
I have mules here so when I free up I'm going to grab one.
https://www.sau.com.au/forums/topic/194126-software/page/4/#findComment-3884150
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
