really it cost me shit loads more than that is all. i will jsut have to see wat the best offer i get is.
sure u dont just want to end the bidding now and take the highest offer of 4k LOL
  • Replies 44
sorry for all the questions. Did u buy all the turbo gear brand new? wot size rear housing on the T04z? wot boost is it running for the 328kw? t4 flange manifold? does it come with all the lines and fittings for the turbo? cheers
running 17psi, can rum more easy i recon, full boost by 3900 4000
do u want to sell the turbo kit sepratley? Im on the gold coast and could also supply u with my stock twins to put back on and still be able to sell the motor complete?
mate dont think you'll get anything near $13k to tell the truth. no offence, but without listing the internal parts, head work done, proof of purchase date and mechanical work, i highly doubt you will find anyone offering more than $8k at most. rb25 gearbox $1200, GTR motor maybe $3500, clutch...$800 for a decent thing? turbo kit maybe a nother $2500 easy. there is your breakdown for $8k. unles you can show anything else of value..(woops leeft out the injectors and cam gears) i dont think anyone is going to be putting their hands up for that much money for someting they have no idea about.
just my 2c-
just my 2c-
hmm forgot to mention, comes will cefiro shell, damaged but reparable so ive been told.
and clutch alone cost 2k not 800
Edited by wolfwood
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
