Hey,
I've noticed lately that on my drivers side when driving i get this " creeking noise " ? i dont know if its my suspenion or yeah, ive heard that it could be the upper control arm bushes. Im not sure but id like to get rid of it quick.
Thanks heaps.
Edited by ezekiel10
https://www.sau.com.au/forums/topic/194825-skyline-r32-gtst-t-creeking/
I also have this problem. Both sides from the struts, pretty much only when its cold. Im assuming may have something to do with strut brace? It may be too tight or too loose? Can someone verify please, it is quite annoying.
Could be a worn out shock. Worn out shocks usually make a 'rubbing' 'creaking' noise when going over speed humps.
Like what's said above, probably best to change the bushes while you're at it.
Yeah " NRV155" same with mine when its cold, but yeah ill get on to changing the bushes and hopefully thats it.
Thanks
Ill do the same. If you get it done first, post back and tell me if it fixed the problem. Ill do mine in a couple of weeks.
My r33 has been doing this alot lately, i can hear it the most when turrning the wheel at slow speeds(ie speed humps), and when pulling into a driveway at angle etc....it sounds like the squeel is coming from the rear, but i can hear the front as well.......sound travels though,.....what is this?and will it progressively get worst?
hrmm i got my bushes changed last week (camber,castor) and i have a creeking sound coming from front passenger suspension when i go over speed humps..Never had that problem before i changed the bushes? Any idea on what it could be?
Well, i took my car to the mechanic today to show him and of course the noise wasnt there, not even going over speed humps. He said when it starts again to go straight to him so he can have a look. Until then, ill never know.
haha don't you hate it when that happens? You go to show someone to show them what's wrong with the car and the problem never happens.
did camber/castor bushes front, rear camber kit, whiteline swaybars with the associated bushes, new bilsteins means that the eye in the bottom of the shock in the rear wont squeak, it was the bushes/bars that stopped my creaking.
-Ryan
Do urethane bushes squeak?
Basically NO. squeaking is caused by high frequency vibrations that can be heard rather than felt. Usually the cause of squeaking is the incorrect application of grease (not greasing the correct areas eg: flange faces & internal bores), greasing the incorrect areas (outside of bushes designed to be installed inside the suspension component) or even over greasing (applying grease everywhere), however the presence of rust, paint or rubber deposits between the bush and the component or housing can also be a major factor.
check your brake pads..
i had this same "creaking" noise on my R32 but could only hear it at low speeds
turns out it was the fact that my break pads were so lowthat the pistons in the caliper were creaking from having to move so far to engage the pad!
Haha reminds me of my old VN SS. It was an auto and was stalling constantly. So much so, I wouldnt bother driving unless I really had to. Took it to a workshop, they had it all day running and constant driving. No stalling...
Got it back the next day. Stalled constantly and I then sold it to a mate and never had the problem EVER.
(And no, it didnt have a clutch! :thumbsup:)
Back on topic, my car does this too.. only out of my driveway in the morning.. I suppose everyone has to wake up :D
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
