Yeh i was thinking it wouldn't make a big difference. I'm gonna stick with a split dump. Just wanna pick a good all rounder.
Thanks mate, i'm interested. If it's a great bit of kit then its a steal. I need convincing cheaper=better :)
Yeah its a pretty good price, so ill have a good inspection of it before it goes on.
I always thought that x-force stuff wasnt the greatest, iv seen a set of their headers, and shit. The S/S is paper thin!! Build quality looks great tho, and in this case, the x-force is more expensive. We will see.
Got mine from bos importing.
http://www.bosimporting.com.au
I ordered one from there and they delivered an AM Performance one so you might wanna call them and see if they can do one for you. I'd recommend this pipe, had a mild tanabe cat-back on before the front/dump and hi-flow cat went in. Is very quiet at idle and when you give it some stick, opens up and has that wicked raw RB sound :P
Hey,
Got my Split Dump/Front from JustJap earlier this week and went about attacking it at home.
The build is really good, the photos on the page dont do it any justice (hint.. change them :) )
So anyway.. my thoughts.
The two problems i encountered, although minor, now i figured out what i need to do means unbolting it again.
1st problem, is one of the bottom nuts on the flange wouldnt fit. The pipe is fat, and bends qucikly out of the flange stealing the room needed to put the
nut back on. Silly me bolted it up anyway thinking id get a mte to fix it ;)
Lying in bed.. DOH, if i had the nut in place on the flange while sliding it on, it would have worked. So simple fix, but being bolted up it means i have to do
it again :) I didnt get any exhaust leaks, so ill wait till i get on a hoist. Its a pain using the scissor jack and stands haha.
Problem 2, is the wastegate pipe touches the turbo water feed.
It not ony touches it but you actually have to push it up to get the dump pipe to fit. In turn, pushing it up also pushes it against the manifold shield.
A quick solution is bending it out the way, i did try this, but f**k me that line is strong! And i dont want to break it off the turbo personally.
Again i will get my mate to have a play as he is RB king. Might even replace it with a braided line so i can put it where i see fit.
It will be ok temporarily, but constant rubbing and vibration it will eventually wear through.
Sorry about the asshat image. My camera is odd sometimes.
As i suspected i didnt feel a great deal of difference. It sounds a bit cleaner than it used to on boost. And for the price, its great :D
  • 1 month later...
Hey Simon, is there any clearance issues with these AM jobbies? After seeing slight problems with just jap ones bit hesitant. im from Ad's so i dont mind checkin this out. Ne help is appreciated mate
Paul
I'm using the batmbl (bosimporting) split dump + front and its a good piece of gear.
If you compare the wastegate piping with the JJR one and the batmbl one you can see that the JJR one has a pretty tight 90degree bend in it whereas the batmbl one has a gentler bend.
Probably wouldn't make TOO much of a difference at said power levels but either way, straighter piping would flow better.
Not criticising anyones pipes , I like the idea of a dump pipe that bolts to the engine pipe because with the 3 bolts/nuts removed you could very likely lift the turbo and dump pipe out as an assembly .
These Hitachi turbos are pretty tight around the dump fasteners and it would make life easy to fit and remove them on the bench . Once the turbo/dump is on the engine fitting the engine pipe up should be same as std .
Just my thoughts , cheers A .
Edited by discopotato03
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
