i found that with my polyglass ... the tweeter is toooo high so i dont' like the sound at all .. i'm going to try and stick it next to the woofer ... if i still dont' like the sound i'm going to sell it and get something else .. maybe dls ... it was hard work getting the speakers in there :)
https://www.sau.com.au/forums/topic/19520-focals-up-front/#findComment-410054
Turn down you're trble on your face unit then or adjust your equaliser for the high frequencies down a bit - thats basically what your split is pumping out after all.
I got my splits mounted just near my a-pillars.. some people say it should be mounted as close to the woofer as possible but i disagree. I think that one can be down to personal taste.
https://www.sau.com.au/forums/topic/19520-focals-up-front/#findComment-413894
i've got infinity reference 3 way splits in my 33 when i first installed them i hadn't installed the mid range so i had some backing plate like the shit you get with headunits and bent in neatly over the woofer in my door and changed the crossover and they crank
https://www.sau.com.au/forums/topic/19520-focals-up-front/#findComment-414293
If your looking at dls, just keep in mind that they are just as bright, if not brighter than the focals, they are from the same make as energy home theatre speakers. pitty you dont like the focals. i cant fault them and i have my tweeters place on the dash reflecting off the windscreen. its all personal taste i guess.
I would highly recommend the mb's to you. just make sure you dont go too low down the range, atleast get the reference series.
how much did you pay for your focals anyway?
https://www.sau.com.au/forums/topic/19520-focals-up-front/#findComment-415189
i didn't think dls were any where are bright as these ... i think the brightness comes from what theyre made off .. titanium tweeteres i think ... i think dls had graphite or paper or something else i can't remember ...
also, does anyone else have any really high quality speakers that fit straight into the stock mounting pod?? i dont' wanna have to go to the trouble of makin them again .. it took forever :P
https://www.sau.com.au/forums/topic/19520-focals-up-front/#findComment-415677
  • 3 weeks later...
i agree with predator666.... I much prefer tweeters up high. Can't stand it down low, it's fine untill somebody including myself sits in the car. Treble is very directional, so needs a clean path to your ears. If my ears were in my knees it might sound ok.
A mates swift has 3 ways at the front, with 4" mounted on the dash and tweeters in the top of the doors. It really sounds great, especially with the speakers on the dash.
https://www.sau.com.au/forums/topic/19520-focals-up-front/#findComment-437547
pretty east to fit, u just have 2 space the midbass driver out of the door with a space made from mdf or such. then if needed just cut away at whatever bracing plastic on the door skin fouls it and brace it up again but around speaker
https://www.sau.com.au/forums/topic/19520-focals-up-front/#findComment-437597
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
