  • Replies 78
Posted Images
http://www.motorauthority.com/news/coupes/...n-silvia-240sx/
What do you think guys? God I hope not. Looks too much like a budget sedan or something.
Doesn't give me tingles up the spine like the S15 did. Sorry it's probably going to have to grow on me for a while.
Like syphillis?
It looks like shit. The front end looks like a Pulsar. The rear quarter looks like a V35 sedan. Considering how nice the S15 looks, this eyesore should not be its successor. Japanese manufacturers should leave building ugly cars to Subaru.
Edited by scathing
I think it looks ok. Seems most people have this perception on what the car should look like. Also keep in mind if its to be released in 2-3 years time... They have to be thinking where things are going to be at then, not now.
Either way it looks 100% better than this... http://www.motorauthority.com/cars/nissan/...sx-replacement/
Much better, but still looks like shit in my opinion. What's the chances of the new silvia looking like that anyway. There's heaps of photos of the NEW silvia and they're all different.
Exactly, and even that article says "This rendering, which turned up on RocketPunch, gives a possible styling direction for the new coupe"
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
