  • Replies 153
lots of people run nos on the street even though it is illegal, most say as long as its not hooked up your fine unless you attract their attention...
I've stayed away from it because of the defect factor... you should be able to get away with it, it would just worry me that one day if you get a defect it means you would have to pull it all out to get rid of the defect notice.... otherwise eveyone would do it...
A good mechanic should be able to do a virtually indetectable install, along with a custom stereo will provide and area to hide the bottle... Thats how mine was anyway...
Bit if its a show car.. its lost all of its bling..
THE RESULTS ARE IN!!!!!!!!!
Ok everyone.... im pretty happy with the final results, i could have gotten more, but decided against it as i preferred to stay in the "safe" zone to begin with.
128 kW at the rear wheels without nos
and 152 kW at the rear wheels with nos.
like i said before im happy with the results, as i have stay in the safe zone.
:D
Not sure about S.A.; but in VIC if a car is caught with any part of a NOS kit installed, a fine of $2000 per cylinder applies. That's right ;) $12,000 for our cars. If this is an EPA issue (not roadworthy) then i dare say the fine applies nation wide.
Not to burst your bubble, but is 24rwkw really worth the risk? Especially when a 100% standard GTT produces that power and probably a little more. Put an exhaust, fmic, Pfc and some more boost, on a GTT, and you wont be anywhere to be seen :D .
hmmm...i would be looking carefully at the graph with the NOS
there is only a 24kw increase in peak power (which is about 32 HP)
really there should be around a 55kw increase as NOS is fairly affective at achieving the stated HP gain...
i want to see a torque curve....
umm... nitrous is basically air just with a slightly higher oxygen saturation (33% compared to ~20%ish)
regardless its still air/N2O (oxygen) under pressure being forced into the intake - doubtful that it would account for 18kw, i think the difference is mainly the dyno.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
