Ryan in the red R33 hear, just to set the record straight troy and damo are the most pussiest skyline drivers i have ever seen. Both are too scared 2 push there cars to the limit both are crap drivers nether can put there cars sideways without spinning out of control. When you's boys are ready to play Ill be Drifting more sideways and racing harder and faster they both of you put 2gether. RED R33 DRIFTGOAT...
BARR... BARR... BARR...
GTS Skyline TopSpeed Record Holder 272@7340RPM
dude give a ****
1 day your gonna be wrapped around a tree
its u guys that give jap import drivers a bad name
every1 says it
all the cops know you
i dont give if i drive like a *****
i got the car cause i like the car
i didnt get it to have an ego and to drive it like an idiot
u sound more like a commodore driver
haah
made us piss
i know u would of but we did the LEGAL LIMIT
and how do i seem full of shit ? :D
also good sound system to me is better than havin a big turbo :(
for now anyway
u know another thing that happened
gave ryan in his red r33 a drag down ewans road
it was a dead even heat to the end
i thought i was gonna get owned
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
