I'm looking at replacing my front rotors and calipers with those off a R33 GTS25T.
Has anyone done this before?
I have heard they bolt straight on, and apart from a brake bleed/fluid, all should work just fine?
Cheers, Chris
https://www.sau.com.au/forums/topic/19587-r32-gtst-brake-upgrade/
I think the only differance is that 32 GTR rotors are a 2mm thicker than 33 GTS25T, and the same diameter (296mm compared to 280mm on ours)
A set of R33 GTR Brembos would be nice - but they'd cost a fair bit
Do you reckon that the master cylinder will still be OK? I can't see any dramas with swapping calipers, so it should be OK. I'm hoping to swap mine over and pay the differance for the calipers and get some DBA slotted rotors with decent pads, probably from Race Brakes or somewhere similar
Master cyliner will be fine, the brakes have just got bigger pistons giving more force but they are not large enough to cause a problem. I saw some 33 Brembro on performance forums for 1600 which is a good price. But i want the option of being able to use 16'' wheels so the 32 gtr brakes are the go and with decent pads and braided lines will give good performance for the lighter gtsts like ours.
Guest Boxhead
im with slip here, eheck your pads, if low, replace with some decent pads, then get some good fluid in there, i used the motul race stuff, its apparently better then dot5.1....
and it made a hell of a difference, you will be surprised the crap that will come out when you flush your system.
For WW2 you will need things for GO mate, non of this slowing down bisso. Look at grepin, he's now got 60% more power than stock and his brakes and fluid are the same from when the car left the factory in Japan!
Im with Slip,
I've got an R33 gtst
bought a set of DBA slotted rotors, only to put them on and find
that both the width and ofset were wrong..
actually damaging the rotors
with that DBA refused to take the rotors back even after they assured me they would ... so if you go this way..check them first
Didn't end up going with the R33 GTS25T brakes, I got some slotted rotors and Race Brakes pads (of Clint32's car which is getting GTR brakes
Didn't think they would make much a differance, but I was wrong!!
Stops heaps better than before, I can now get that good g-force feeling under acceleration and braking now
Will need a track day to give them a good test, but so far so good
Also, big thanks to Clint for helping me out with them - cheers mate
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
