i was looking for something different to do instead of LED tail lights and found these two pics in my travels.
anyone else like these for something different?
made by Tomei i have a feeling they'd be rare as, perhaps they could be replicated
i want some !
https://www.sau.com.au/forums/topic/195886-r32-owners-sick-of-led-tail-lights/
im not really a fan of them-my 2c
and yeh not a fan of the led lights, look cheap i dunno mayby its just me lol there are some on the 34 that look pretty cool tho, kind of like crystal lights, not typical led style
i've got a set of those, not made by tomei though... still haven't decided to put em on though.
you could very easily make them out of the bottom of glass jars :)
get some r33 tailights, they're the best
and you know it :action-smiley-069:
Yes, R33 lights are the best, BUt in the 4 door variety.....very nice indeed. Maybe try fitting them to your 32, that would look mad!!
Crap sorry, flood control locked me out for a second and i thought my post didnt go though, sorry!!
EMZ
Edited by EMZ R33
whats wrong with led's?
they go well with the ganadors and soon to be clear headlight covers..........................
I have the same lights on mine, I love them.
Havn't had any bad feedback on them in real life yet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
