I fang mine around all the time. I'm not saying this to sound cool. I just dont drive it like a granny. Im not really fussed about fuel consumption as I didnt buy the car for that.
Before you say I drive like a dick, I dont swerve in and out of traffic, dont speed in excess and never lost a point. I just sit a gear lower than I should all the time :thumbsup:
  • Replies 54
^^^ that's crazy man..
you'll wreck your engine.
You gotta warm it up..
like me..
each night, I put a container of oil in to a speacially built room which is heated to 80 degrees.
before I start my car in the morning, I pull the head off and put a little bit of this pre-heated oil in the pistons to make sure they are lubricated and warm.
I then torque down the head and put it all back together.
I then proceed to take the turbo off, pull it apart and lubricate the bearings with the same pre-heated oil.
I then put it back on.
Then, I pull the injectors off, put a little bit of fuel in them and install them back in.
I remove the spark plugs, put them in the heated room for 20 minutes to warm them up, then install them back in the car.
THEN, I put the key in the ignition, turn it to reds and wait for the pump to prime.
Then I crank it over and start the car.
At this point, I let the car idle for 55 minutes exactly to make sure it has warmed up properly.
While it is doing that, I jack up the car and spin the wheels by hand then run to the drivers side and step on the brake.
I do this about 15 times to get a little bit of heat in to the brakes.
after 55 minutes have passed, I remove my tyre warmers and thermal blanket off the car and drive slowly, making sure I don't go over 0 on the boost gauge and not over 1500rpm on the tacho.. for at least the next 10 minutes.
At this point, it is safe to drive the car to a maximum of 3200rpm.. you don't want to thrash them over that..
Revs kills engines you know..
This routine takes about 12 hours each morning, but it is well worth it.
I strongly suggest you all do the same thing..
You would if you really cared about your skyline.
I dunno..
I mean to save all that trouble, I would just up the time spent on limiter to about 6 minutes.
Gold! LOL
like me..
I take 12 hours and 30 minutes... can never be too careful :cheers:
oh and every 1/2 hour I replace the air filter element, I keep my boot jam packed with the suckers
What's boost?
I rarely use it... Probably about once a day I hit it, and it's due to a VERY poorly designed on ramp near me, speeds usually drop to 40 odd km/h in a 90 zone... Using 3rd gear I pull onto the outer lane with a decent amount of throttle (Mind you, I do it in a safe gap too!) and that's normally only low boost too.
I rarely hit full boost, maybe once or twice a week.
I just baby it, it's driven daily, and there's no need to hit full boost on the way to work.
yeh im with most ppl here... dont go over 3k till oil n water are up to temp. I never bother with warming up apart from getting up to oil pressure cos ur diff n trans dont get warmed up sitting there stationary! Most of my day to day driving is putting about off boost, with a squirt here and there. Dont usually get over 4k. I do however drive in the hills a couple times a week to blow the cobwebs out :P
^^^ You're getting a Handbag for xmas aren't you?
or maybe a towbar for the skyline so that you can tow your dresses.
No sweety, I'm just going to keep carrying yours around for you, as I don't want you to hurt yourself lifting something so heavy for you.
Seriously, it's a public road. The amount of people out there in peak hour traffic that jump and change. If you're hammering it, and they change lanes, it's an accident waiting to happen.
I actually found some good statistics not too long ago on the RTA site.
Approximately every 3 KM someone makes a mistake that could lead to an accident
Every 8KM someone makes a mistake leading to a near miss.
So if you drive 10km to work, you're bound to make 3 mistakes, with one leading to nearly having an accident.
You start flogging your car, those distances drop down quite a bit lower.
Wisen up or go buy your self a push bike
I've put those two words in bold, because it shows you dont know how to understand data. Someone out of XXXX amount of cars on the road makes a mistake every 3km. That doesn't mean that it is you
And I did buy a pushbike, thanks for asking :P
Sorry Jas, the stats actually was each average person.
I'll try find them again for you all. It was one person out of everyone, it was each person makes a mistake approx every 3km.
Each has a near miss approx every 8km.
Okay, got the stat SLIGHTLY wrong, but:
Crash research shows that all drivers, even
you, can and will make mistakes. It is estimated
that drivers make a mistake that:
Could lead to a crash about every three
kilometres.
Leads to a near crash about every 800
kilometres.
Leads to a crash about every 980,000
kilometres.
Page 30/31 of 94 of the Driver Qualification handbook
Start driving like a tool, you manage to lower those distances DRAMATICALLY!
Driving fast actually does save petrol,
unless you're coming up to a red light and still doing 70km/hr until 50 metres before it.
So I tend to accelerate faster than normal and go 5-10 above the limit unless overtaking
also shifting to neutral when going down steep declines helps a little :P
So if I drive 42km to and from work then it means I make 14 mistakes everyday?
Doesn't sound right to me, I mean even Mr Bean doesn't drive that bad
i never go over the speed limit. but ill do my best to get there as fast as possible.
i can't think of the last time i waited for my engine to warm up before hitting full boost.
limiter get a bashing daily.
stupid i guess, maybe ill learn when i have to replace the rb20. or crash.
when i drive normal cars(Camry) i drive granny spec, but when your behind the wheel of a skyline you can't help it!
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
