hey guys,
I pulled into the petrol station today to fill up (after a 80k freeway drive, mostly doing 110kph), and was about to shut the engine off.
It suddenly started making a real loud knocking/banging noise, and idling rough. It sounds like the noise is coming from the top of the engine, but i can feel it through the clutch pedal.
The things ive checked so far are the oil and coolant, which are in perfect condition.
The spark plugs are in mint condition.
I had a look at the pistons with torch and they look excelent too
I pulled the cam cover off the intake side(which is where the noise sounds like its coming from) and everything looked to be in order.
the only mods i have are a pair of pods, and a cam gear. car is driven daily, but not thrashed daily (although it copped a fair bit saturday). Oil changed every 6000ish k's, and its always run on ultimate 98. Its never caused any problems in the 2 years ive had it.
When you crank the engine it doesnt make the noise, only when it fires up.
im thinking the timing belt has slipped a tooth, the cam gear has loosend, or there is some serious bottom end bearing damage.
I know its hard diagnose problems over the web, but any ideas would be great.
thanks heaps,
steve
Edited by PHATR32
Big guess to say it's slipped a tooth. How olds the belt in it?
I wouldnt think a big end knock (bearing issue) would cause it do idle funny...
Could be the other way around. If the cars missing (usual AFM, AAC etc) the piston can do funny things when it goes over TDC and doesn't fire. It can knock about... thats possibly what your hearing.
Sorry I'm no real help, just some thought :)
try and issolate a cylinder if possible. depends how harsh the noice is, wouldnt wana cause any more damge. however by issolating the cylinder your in the general direction. could be a collapsed lifter?
they actually have solid lifters and naturally have fairly loud heads.
My mates GTR had simular noise, sounded like it was in the top of the head etc etc etc, turned out to be a bottom end bearing spun. worst case scenario and for your sake i hope its not.
well i took off the cam cover from the other side (exhaust) and it looks fine, also the timing belt is fine and the markings are exact. the adjustable cam gear also hasnt moved from 0.
i turned the engine over a few times by hand and found it gets stuck when cylinders 3 and 4 are at TDC (or there abouts).
it will turn over bout 2 or 3 times and id feel slight hesiation (cyl 3 and 4 TDC) then on the next turn it would get stuck to the point where id have to give it a bit of force to keep it turning.
Ive checked the belt incase theres a rock or something in one of the teeth but i found nothing.
the tapping noise is REALLY loud btw, but i havnt reved it over 1k, only idled it for a few seconds.
steve
Im very new to skylines and this is probably wrong but thought i'd throw it out there for the hell of it
My brothers r32 (rb20) started making a really loud tapping/knocking noise a couple of days ago, would rise with revs and sounded like it was from one of the front cylinders. It actually turned out to be the clutch on the fan had given up and was making the racket. Its easy enough to test cause you can just slip the belt off and see if the noise goes.
My 2c worth
*Edit* After reading your latest post, probably not what im suggesting...
Edited by Scottydoo
lol, i got shit in my wallet......
when i push the clutch in it still makes the noise, that said, i could definetly feel the banging through the clutch.
although, the clutch wouldnt screw up exactly when pistons 3 and 4 are TDC.
i do all the work my self, of course if the engine requires rebuilding ill have to get a pro to do it as i dont want to risk screwing it up etc.
ill do a compression test tonight to see if itll show anything?
steve
Edited by PHATR32
hey guys,
i just ran a cold compression test and all cylinders were between 135psi - 140psi except for cylinder 3 which is at 45psi!
as mensioned above when i turned the crank by hand it would get stuck when cyls 3 and 4 would hit TDC.
so i pulled the cams off and took off the lifters on cylinder 3. it all looks ok, and the valves move in when i apply force. How can i tell if a valve guide has dropped?
im gonna have to pull the engine out either ways but would anyone have any idea on what could be causing the banging and low compression?
thanks guys,
steve
Edited by PHATR32
well, ive been pull the engine bay apart these past few afternoons, and found the pipe that controlls the wastegate actuators had come undone!!
weird thing is i hadnt noticed any increase in boost?? that said, i do have a stock exhaust.....
engine will be out and apart this weekend hopefully.......
i would put money on a spun big end bearing!
i know that sound well, sorry to hear that.
most the time when a big end bearing starts to go , it sounds like it's coming from the top.
russ
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
