Anyone get K.O'd by the huge dumping of rain an hour ago?
Our drainage got blocked and flooded whole garage. Was seeping under the concrete of the floor.
My room is next to the garage so my wooden floor probably going to be stuffed hehe.
We have insurance but still a hassle oh well.
Pix!
https://www.sau.com.au/forums/topic/196099-flooded/
pwned! down incline driveways FTL.... unless u have a big ass grated drain at the bottom to redirect the run off water..
I got a down incline driveway. It sucks. I just spent the last 15 minutes removing all my stock parts from the garage floor as it was starting to flood. Mine is so steep i can't park my car in there without scraping the front bar. I even have one of them big ass grated drains too :action-smiley-069:
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510387
LOL - doesnt sound good out eastside today.
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510420
dam.... we have a downward inclined driveway too but we have a grate and piping which stops that from happening... luckily... not that i would be too worried about my VL getting a swim... in fact i would prefer it did... its insured for more then its worth and it currently isnt running :action-smiley-069:
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510540
Pat my bedroom is a bloody garage. i got all of my crap from 1 side to the other. emptied out a good 50L of water with a huge 10L bin....
mouldy carpet smell is awesome......
anybody complain about their garage getting flooded ill personally bitchslaps ya!
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510706
On a serious note, if people need assistance with flood or water damage, examples are flooded garages :action-smiley-069: water in houses leaking rooves etc call the State Emergency Service (SES). 132 500. You will be directed to call 132 500 if you call 000.
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510714
I was at work all day, anything that could have gone wrong, went wrong. We had 6 major leaks, and a tram got hit by lightning right outside! on top of that, as whithorse road was flooded there was water simply flowing in the front door... it all make for an exciting day, as none of the stuff getting damaged was mine :D
https://www.sau.com.au/forums/topic/196099-flooded/#findComment-3510754
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
