Fellas,
As the subject suggests... I got myself a nice HKS SSQV s2 (atmospheric) B.O.V a couple of weeks ago and my car's been stalling like a sick dog for no reason... the sound of the HKS isn't actually top-notch either so I've decided to go back to stock... as I don't want the car to keep stalling and the stock SSHHHHHH sound isn't too bad either...
Was wondering 2 things...
1) Anyone experience similiar issues with Atmo B.O.V's?
2) How do I make my stock B.O.V sound better which makes the nicer and louder sshhhhh sound?
Regards,
Edited by Spunky Munky
https://www.sau.com.au/forums/topic/196781-r33-stock-bov-the-best-for-the-car/
Just to save you the flame, have a quick search and you will find many topics about this.
Skylines dont like atmo venting BOVs.
Stick to stock. Theres nothing wrong with it. And if your only after the sound, well... thats another story.
Stock is fine up to a certain point, after that get a stock gtr one
a full plumb back (or atmo, its adjustable) GFB Stealth-Fx bov can be found for near-enough to the price as a gtr unit, if 3rd hand is good for you ;)
works great, bigger turbo holds boost better (was bleeding off too much), and it doesnt sound stupid in full plumb back mode, a little flutter of air reveberation between turbo and afm when you lift off the throttle
ecu with safc (tuned to previous bov) works fine with it
awaiting a hks actuator, so will retry stock bov but I feel that 16psi was a touch too much for it (dropped to 14psi all the time)
Thanks fellas... I guess, there's nothing wrong with going stock... besides, the POD has good stocking and let off sound so it's not too bad (sound wise)... as for the atmo one... man, bleeding and stalling like a biagge.... lol....
Anyone know how to modify the stock one a bit to make it sound better?
Search the DIY section but found nothing.
rev can you link me to the diy mod to make it hold boost?
this one : http://www.skylinesaustralia.com/forums/St...html&hl=bov ?
"Crushing:
"Crushing" the BOV just means sticking the piece in a vice and pressing the top had down causing the internal spring to shorten and increase pressure on the BOV valve."
will try !! =D
Update: Installed the stock BOV on my car this morning... at first (maybe because the ECU) was still adjusting... it kept stalling... but then after an hour or so, it tuned itself and is running nicely now ... no more stalling... damn, spent a bit on the HKS SSQV and now back to stock... some times it's not worth modifying.... I'll let it run a couple more days before giving everyone a run down. Thanks.
Isn't there an attachment for the SSQV which allows it to be plumbed back?
Although stock is good, its also about 15 years old.
Plumbing back your new one might not be a bad idea... just my thoughts.
R31Nismoid, I he might of been referring to the ECU getting out of limp mode?
Stock ECU is a learning ECU right?
Edited by infamous_t
stock ecu is a learning ecu. if they are reset or things change they adjust accordingly in very minor increments. that would explain the time taken for the car to adjust to the bov change.
"Crushing:
will try !! =D
Err...no. Although it appears that does work for some people I don't know that I'd give that one a crack unless you had a few spare stock BOV's.
The mod involves little bit of a drilling, you should use a vice however to hold things while you drill though.
Someone did post the instructions up some time ago. Will go for a search for you.
my hks ssqv bov never made my car stall. aslong as you keep the standard bov plumback and set up a t-peice in the vac line it will run fine. if you only run a single vac line to the atmo it'll start stalling and what not.
My ssqv replaced the standard bov in the factory position and i don't have any problems using the single vacuum line.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
