Hey everyone,
Im possibly about to purchase a pair of Garrett 2860-5 turbos. Can anyone tell me the differences i will most notice with either 0.64 and 0.86 exhaust A/R's. At first i didnt realise but now i have been informed you can choose from the two A/R's on the exhaust housings. Keen to hear of what either will do to overall power capability and response. I have my guesses but it would be nice to hear from people who have actually tried and tested them. If anyone has any other turbo options with similar capabilities at a similar price i would also be interested in them too. I want to keep the twin setup with the stock manifolds.
Thanks in advance,
Deren :D
https://www.sau.com.au/forums/topic/196840-which-garrett-turbos-should-i-get/
Ok. Thanks for that. I guess my stock capacity wouldnt help anymore either! Anyone else got an opinion?? Sounds as though the .64 is the way to go but maybe someone has a dyno graph for each?
Thanks
Edited by Godzilla32
.86 rear isnt that big..
i had a 1.15 rear when bought it on my t04 changed it to a .84 and now its fantastic spools up very similar to standard with none to minimal lag.
every turbo and rear is different in lagginess etc. Garrett website should have graph's
.86 rear exhaust housing on a single turbo maybe BUT not 2 of them, its like using a 1.3L engine to spool up a GT2860 with a .86 housing
Deren,
Have you considered what the power and responses you want from your car afterward?
Maybe look at the gt-ss kit, almost the same price.
In saying that and tossing up which turbs to buy myself, I have a pair of new 2860-5's sitting here in my office waiting for christmas to fit...
i'm looking at getting the GT2860-5's myself.
who stocks them for $2500?
i was planning to get them thru super cheap auto, staff discount brings them down to around $1100 ea.
however the garrett website says that the 2860-5 comes with the 'compact 5 bolt' turbine outlet (which won't fit standard dumps) , but the 'turbine housing option' is needed to keep your dump pipes.
I'm not sure which SCA stocks
hope it helps
Standard capacity 2 x 2860-5, PFC, dumps, injectors, "Spec R" Cat 3inch zaust. 430RWHP @ 1.3 bar, lag...pfft,just be in the correct gear. Go for the .64. If your going down down the road of new turbos go the dumps to...Tomei if you can afford.
Ususal Suspect..theres a pair in the for sale section
Hey heller44, would you mind checking the ID tag on your 2860 -5's. Apparently they are now badged as 2560 -5's but still have the 2860 -5 specs.
I did look at the HKS GT-SS turbos but after a comparison i found the garrett 2860-5 will flow more with nothing lost in response.
A garrett 2560 is a turbo designed for the SR20DET. I fitted one about 6 months ago.
I was planning to get a set of CES racing dump/front pipes, similar design to the trust ones. Its a combined dump/front pipe but its assembled in 3 pieces.
Im a bit concerned now that they wont bolt upto the standard dump pipe flange design?!? Can anyone confirm this? I have my doubts that it will be an issue.. Better to be safe than sorry though.
Who sells them for $1200 each? Keen to know..
Thanks guys for all your input :P
Deren
Deren, I'm pretty sure that the 2860R-5 will bolt up, they were sold to me as a "direct replacement". If split dumps are your preference why not go with the Trust extension front pipes a few guys on here claim good results with them although I'm told there seems to be a bit of a trick fitting them. Ring up a reputable tuner and see what they have to say. GL
I Thought the 2560 was the old name and the 2860 was the new name???
hmm... very interesting.
id tag says,
KJ 0134J
GT2560R
707160-5
Strange that they are still using what I thought was the old gt number even though the part number is the same.
Checked with the dumps that I have here and they match up perfectly, a set of secondhand old-style mines dumps, that will go nicely with the secondhand apexi front pipes... gotta love parts that don't wear out.
edit: Whats a 2530 kit going for now delivered? ~$3500? I bought my pair for $2540 delivered, and then had a brain fart and bought the fitting kit from nengun.. waited over 2.5 months for delivery but I have it all for significantly cheaper than the 2530 kit.
Edited by heller44
707160-5 thats the ones...
from the cattle dog
Turbochargers > GT28 Family > GT2860R - 707160 - 5
Ball bearing
* Oil & Water-cooled bearing system
* T25 turbine inlet flange
* Turbine housing has a unique "compact"
5-bolt outlet that is not interchangeable
with traditional T25 5-bolt outlets
* Turbine housing is cast from high-nickel
"Ni-Resist" material for extreme
applications
* Turbine wheel is cast from "Inconel"
material for extreme applications
* Great size for applications w/ packaging
constraints
* Ideal for smaller displacement engines
making up to 320 hp
* Ideal for twin-turbo applications on medium
size engines making up to 600 hp
* Turbine housing option available
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
