here are a few pics of the rims i just put on today. they came off my mates r32 that is defected at the moment. im thinking about buying them but i think im going to have to lower my car to fully appreciate them. they are 18x8.5 front and 18x9.5 rear.
post-44842-1197198164_thumb.jpgpost-44842-1197198106_thumb.jpgpost-44842-1197198077_thumb.jpg
https://www.sau.com.au/forums/topic/196880-rim-pictures/
Just double check that the rolling diameter of the tyres are the same front and rear. Sometimes different width tyres run slightly different heights, which can cause dramas with the attesa, according to a few on here.
But going by how the rear tyres is stretched on there id say they are the same width TYRE front and rear, even though different rim widths...?
Looks good tho! But yes lower the car!
https://www.sau.com.au/forums/topic/196880-rim-pictures/#findComment-3522742
yeah its the dayz kit. i pm'd sk about some suspension but havent heard back yet. i have a RWD so i havent got an attessa system to worry about but yes the tyre widths are the same front and back
i reckon a gtr bake upgrade might be on the cards to fill the rims up a bit also and to stop terrible braking perfomance of my car. went on a bit of hills drive last night with a loaded car (5 people) but with the stocky wheels and wasnt terribly impressed. i definatly wasnt being given any ammount of reasurence from the suspension or the brakes. im a bit of a pussy driver now after my accident and any hint of body roll freakes me out.
https://www.sau.com.au/forums/topic/196880-rim-pictures/#findComment-3522851
wats the offset for fronts and rears?
im getting an 18sx9 for the front and x10 fortherears. Front offset is +25 and rears +40
I think you are going to have rear inside clearance issues with an offset that high.
My 18x20 rears have about a finger of clearance (13-17mm). I don't know if an extra 20mm on the inside will fit. You definately wont be able to run square rubber (where the tyre sticks out more than the wheel)
https://www.sau.com.au/forums/topic/196880-rim-pictures/#findComment-3525630
spacers as a last resort 10mm should do it. Then i will look VERY Ricey!! :D
https://www.sau.com.au/forums/topic/196880-rim-pictures/#findComment-3526441
Hrm so its okay to run staggered widths front and back as long as rolling diameter is kept the same?
I've been looking for a set of equal width 18" rims for ages on various car forums and its so bloody rare to see any.
What size rims and tyres (inc offset) are you guys running? I need a rough idea on what will look decent.
https://www.sau.com.au/forums/topic/196880-rim-pictures/#findComment-3526575
where in victoria can you go 140km/h+ ?
140km/h is not rarely seen. Yeah.. racetracks.
dmonic1 what offset are those rims?
I am currently looking at a set of 18 x 8.5 and 18 x 9.5 +35 offset, just wondering if they would fit without having to lip/roll the guards.
At your sizes and offsets, comparing to my rims (which are slightly weaker than Yoko) you are going to have 28mm less inner and 40mm more outer clearance on the front and 9mm less inner and 21mm more outer clearance. Stagea's have MASSIVE front guards man, you really need lower offsets on the fronts than the rears. Be careful of hitting the shock too (the curse of high offset wheels)
You can compare to other sizes using this calculator. http://www.1010tires.com/WheelOffsetCalculator.asp
I havn't touched my front guards and my rears would be alright slightly higher, at this height they need a lip only (bend the inside lip up, not pump/roll/flare the guard)
Yokotas old car (18x9 -5 w/ 235/40 fronts, 18x10 +20 w/ 235/40 rears)
My car (18x9 +1 225/40 fronts, 18x10 +20 w/ 235/40 rears)
Edited by AlexCim
https://www.sau.com.au/forums/topic/196880-rim-pictures/#findComment-3527380
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
