hey guys,
as some of you may know, about 3 weeks ago i road off my r33gtst on the gor cruise. :) the time has come and so has the insurance money, to buy another car and am now in a position to buy an r34. Write off was a good excuse to upgrade. :(
Car 2: 99 R34GTT. grey, nismo kit (factory kit) other than that standard.
thanks in advance for some help with my decision.
MY BEAST IS BELOW
Edited by cheez
https://www.sau.com.au/forums/topic/197077-stuck-on-colour-choice/
  • Replies 47
Posted Images
ive test drove both, exactly the same. the have the same handling setup and sae diff and gear ratios. neither have been molested before by the looks of the interiors and engine bays.
+1 for yellow
every second car on the road is silver and you can always get a kit for it later on
there are a couple yellow 34s in my area and both look pron! eventhough both have chromies...
silver's just too boring.
kthx
EDIT: thats the japcar in fawkner yea? wats the cheapest GTT they got? :(
Edited by R-SPEC
yeh its jap car in fawkner. i bought my first car off him so went back and hes doing me a good deal. price wise the grey and the yellow are the same, 22k approx wit on roads. so for me its just a colour choice.
My cousins good friend owns Jap car, are you dealing with Dennis?
Some very good cars have come out of that yard, inclduing a GTR that was posted up in the VIC section not to long ago that made close to 300rwkw.
Owner didn't know it had high flow turbos and a chipped ECU, thought it was stock with an exhaust. :(
Edited by abu
