OK so I ran a search and looked here and there, many running a few piston types and brands. Looked through the thread in the quick ref as well. Something that seemed to be missing from many of the threads were a few possible choices and perhaps some info. I am wondering why I don't see many if any Jap brand names being thrown around, is it purely price? So far I have learned Venolia are at least 'buyer beware' and most others are quite good as long as the clearances and ring choice are right. That and the engine builder doesn't do something dumb :D
So how do the Jap brands stack against the more common ones I see here? Is it purely jap brands are too expensive or are there other issues? How many actually manufacture their own or are just reboxed?
JUN
Tomei
HKS
Wiesco
CP
JE
Arias
ACL
https://www.sau.com.au/forums/topic/197191-piston-choice/
jap brands tend to use the best pick of piston manufacturers and use specific models, ie the trust pistons i use in the top SR's i build use a crown design and special ceramic coated rings only available under license through trust even though the manufacturer makes "other" SR20 pistons.
Arias are a good budget brand and i use them mostly on budget builds but i am not a fan of dished crown in any HOT SR20 i prefer the flater notched crowns, i am currentley building a test engine with SRP (JE). so i will soon know what they are like.
i dont know of any jap manufacturer that manufactures their own pistons but most are made to spec and are not available in another brand or boxes, they are made under license.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526353
Interesting. Personally I am looking at a Tomei forged piston kit for my RB25DET however I'd have other things to sort (like being able to drive while R33 is off the road) before embarking on a full rebuild.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526368
you need to look a a few things to determine whether or not you 'need' the extra benefits offerred by these dearer pistons, on many builds i will talk a customer down and prefer they spen money elsewhere for their application but for extreme and high hp and high rpm i prefer the jap brands as they tend to offer a better life cycle and in SR's they offer a unique crow design and ring combo..... oh and zero noise.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3526392
Mostly what people think are a good piston rather than actualy using them but still a bit of info there.
So JUN/Cosworth, HKS, Tomei if you're 'loaded' or chasing big power figures otherswise CP, Arias, Wiseco etc will do the job cheaper. Venolia if you want to brake something.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3527462
ACL and CP pistons are both very good pistons for the pricing... I personally prefer ACL as they have a better ring kit... Piston wise they are both very comparable quality....
I'm personally running ACL pistons and have had no problems
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3527639
you say hks and jun pistons if u chase big "power figures" who said u cant make 1000hp with a set of CP's? a set of well made forgies is what you will need. You can get a rebuild kit from racespec for a couple grand..
Edited by LTHLRB
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528520
i can see where he is comming from though. he said some manufacturers have certain technologys which is only available by licence so you will need to go with the jap brands that have this available to get it.
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528527
what has stopped the old boys from making 800hp in a big block v8 n/a?
if you want to have that backing then yeah use jap brands.. but i would only use jap brands if im using a full kit (stroked engine) like full hks, tomeii or nismo.
just talking like this because iv seen ALOT of engines built with arias, acl, cp and wiseco
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528557
nothing is stopping anything. i have ACL pistons in my engine as im not made of money.
I would like to have the jap stuff in my car though.. they build more RB engines then us... well that might change soon though lol
https://www.sau.com.au/forums/topic/197191-piston-choice/#findComment-3528858
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
