okay guys... there have been a few dances around the subject of this particular turbo....
I have had my car off the road for a little while getting a full rebuild with the following
Engine - RB20 ---> RB2.3
-forged pistons.... yadda yadda..... all new block...
-1.2mm tomei head gasket
-Tuneagent low mount s/s lowmount
-HKS split dump pipe
-Free low straight zorst
-Nismo 555cc injectors
-Z32AFM
-Tomei Poncam 256/256
-Tomei Camgears
-Nismo FPR
Now the turbo i currently have is an HKS 2510..... i want to go bigger down the road as the engine in built for it now.... but on the previous standard engine it used to make 181RWKW on a conservative tune at 1.bar.....
i have witnessed these make 200RWKW before at same or a little more boost.....
ive read that chris32 had made 208RWKW at his highest recording.....
in question if i rung my setup for all its worth i would be able to get 220rwkw on a 2510???
I really wanna see what this thing can do....
i think if that if that figure could be achived i would have a demonically fast street car......
thoughts please......
all comments welcome....
Edited by new blood
I think if you worry too much about chasing a number you could end up hurting your nice enw engine. Tubn eit up, run 1.3bar in it and it will make whatever power it makes. No doubt it will be quick, whatever the numer is
If you really need 220rwkws get the tuner to use a cup of coffee...or whatevcer it is they do to fudge figures :D
Too small IMO , a HKS 2510 is just a 2530 with with the more spool friendly - and restrictive - GT25/28 turbine . Aside from a few more recent HKS options ie GT-RS much of the HKS Garrett GT turbo range have been around a while .
One of the best all round in its turbine size range is the 2530 IMO . Your call but with what you've done to your RB20 to make it breathe the last thing it needs is a restrictive turbine to choke it up .
My vote goes to an RB specific 2530 .
Cheers A .
I agree with the above that this new engine deserves a bigger turbo.....and i will be leaning towards a GTRS when the time comes......
I just wanted to put to rest the myths that dance around this turbo.... i have always loved the power delivery of this one... and even with 180RWKW that it previously had.... it was so much fun.... max power is never the issue with me.... i just loved the mid range torque it produced.... and regardless of what others have said... it pulled all the way to redline.... never felt like it dropped off....
So...... i figure with all the mods done.... and having an engine that is supposed to be "more efficient" than the turbo... at least we will know what can be expected out of this little snail.....
  • 3 weeks later...
hmmmmmmmm............ seems i have run into a few little difficulties in preparing the engine.... anyways... i should have the thing back in the car first week after new years... will then run in.... and then off for final tune and detailed results......
  • 3 weeks later...
well... long story short..... engine not back yet... so further delays.... ive had a little more time to cash up again.... and a new turbo is starting to look good just about now.... should i rebuild my current 2510 with a 2530 or 2535 core?
thoughts please
thoughts please
thoughts please
I guess it boils down to how much power you want and how much you want to spend...personally i recon a 2535 would be awesome for a rb23...and be good to around 220-240rwkw with pretty decent response...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
