Well it is all happening!
We only have 6 odd weeks to have the car reliable, guaranteed we are coming back with a blown this or that... but also the thirst for a somewhat competitive car in 2009 - you gotta start somewhere!
Duncan - our only legal option is to run the ceramic turbos is it not - or have them rebuilt with a steel wheel CHRA? Someone mentioned earlier that to swap to N1 we would need to be entering the car as N1 spec and actually have an.. N1.
Can't wait to get over there!
  • Replies 60
You DON'T actually have to have a genuine N1, just enter it as such. But, you need to have all genuine N1 bits on there, such as factory oil cooler, N1 spec turbos etc. I reckon it'd be worth the exercise just to have that little bit of extra reliability up your sleeve.
Keep in mind that technically you cannot run a GTR with so much as an oil cooler if it wasn't on their from factory. Hence nearly everyone runs as N1 spec. :O
Btw, great to have another Skyline there :D
Edited by Marlin
You actually have to have a genuine N1, just enter it as such. But, you need to have all genuine N1 bits on there, such as factory oil cooler, N1 spec turbos etc. I reckon it'd be worth the exercise just to have that little bit of extra reliability up your sleeve.
Keep in mind that technically you cannot run a GTR with so much as an oil cooler if it wasn't on their from factory. Hence nearly everyone runs as N1 spec. :D
lol you forgot a very important word 2nd in that sentance "dont"
but you are right about the trade off. the n1 turbos are too big, but 16" wheels are too small. lots of compromises.
Is an N1 oil pump required?
I am thinking the higher flow is more likely to cause oil issues without any internal engine mods to oiling for the head. We are trying to avoid cracking open the motor at this stage.
Also just trying to get our hands on some N1 "lagmasters" - one guy looks to have the R34 N1 dumps as well which could be a good bonus - you guys know of any issues fitting these in the 32 with the standard front pipe positions?
Oh and if anyone has an N1 oil cooler, power steering cooler or water pump we are in the market BIG TIME!
Edited by paulR32gtr
well strictly yes, if you run in n1 spec you can't pick which bits you want. but the n1 pump flows less not more than a standard pump. also targa seemed to be easier on the motor than circuit racing you are not doing as much sustained high rev stuff (yes on the big straights, but there is a lot of mid rev tight stuff too)
re the 34 n1 dumps, they of course are also not legal on a 32. I am pretty confident they would bolt straight on though, only difference would be the rear dump has an exhaust gas temp sensor fitting.
i had to get my 32 n1 turbs from nissan on order from japan. no-one else was mad enough to want a set of them I guess :( the 34 n1s are a much better unit (ball bearing v 270o thrust bearing) but not legal
having said all that, I didn't notice any eligibility scruitineering last year at all. Another GTR we went through with clearly had aftermarket injectors for example.
Sweet re: oil pump - Steve already bought one! I do now remember hearing that they flowed less - thanks.
How much were the R32 N1's and how long did they take to get here? Edit: spose i should just get on the phone to nissan eh!!
We are looking at the G4 Racing AP copies - just hoping they will fit under 17x8 / 17x9 wheels
Ben you mentioned being able to run 18x9 under the option rule - what does this entail? Couldn't find it mentioned in the regs.
Stu Benson (tech reg guy for Targa) has told me that cars are alowed to run wheels that were option parts. The R32 GT-R had 17x9, and 18x9 wheels as an option from the factory. R33's had 18x10 optional wheels from the factory. The old CAMS regs had the option rule in there somewhere. Best bet is to email Stu.
Just found the regs. 301.9 http://www.targa.com.au/Competitors/Regula...icalGeneral.pdf dosn't say anything about wheels though?
Hi
Re the options on wheels, I read the new regs and it does not say you can have option wheels so I am not sure you can.
The other thing to remember is that if you run an option you need to be able to produce proof as per the regs.
That proof must be in one of the formats defined in the regs.
Just my thoughts, happy to see the rules that say otherwise.
BT
wheel options were removed in error from the regs, but will be re-included via bulletin shortly. sorry for the confusion.
paul - further to your email, lee also took the turbos off my old GTR and replaced them with something else. i doubt he'd be after big dollars for them. they made 260kw on 16psi and 95ron with a 3.5" exhaust with a very very mild tune.
Hey whats the deal with exhaust regs?
Had a chat with Ben @ Racepace and he mentioned we may be limited to a 3" exhaust maximum on the GTR? Ouch...
Stuart - those turbos were genuine N1's?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
