  • Replies 41
Posted Images
Had a moment of weakness and slipped over to the dark side this weekend.
Long story, but short version is i brought this and collect at end of feb
:P!!! nah just kidding! :P
very nice!! whats the plans for the 32?? track only car??
Ps. Porsche isn't the darkside - Toyota would have been darkside!! >_<
lol that reminds me of that old adage.
"How do you tell the difference between understeer and oversteer? with understeer you see what you are about to hit"
I guess its a good choice if you can't get a line on the road.
Very hot 964 mate, it looks in fantastic condition,
A friend of mine has a really nice white 964 that is used for track duties here, although it's not the turbo it sings along very nicely and the noise it makes when the cam opens her up is phenominal...
Just wait for some cool temps around 1am and hit the desert roads!!!
spot the porsche nerd vvvvv :):)
Very nice indeed mate, top choice! Looks to be in fantastic condition.
Troy, the 993 GT2 was the last of the air cooled RWD 911's, with the 964 being the last of the single turbo rwd 911's. :)
Hi
NYAAAAAAAAAAAAAAAAA
Dean's old man's 964 is unreal. What a noise!
  • 2 months later...
Well ok its finally here and registered for road use!
Its quite different to drive a 3.6 litre single turbo engine, the torque is unbelieveable, not mention the sound the old girl makes basically has a screamer pipe from the waste gate all of 15 inches long. It fairly howls!
Going to do a dyno run in near future to see what its producing they are around 360hp standard but this one has hi flowed kkk 28 turbo and some mean cams should end up around 400 ish i would think at one bar.
will take a clip and post it for those interested in old porsches
Giday Russ!
Awwww bugger that mate how about i send you a link :-) short story is we are a large generator hire company
www.aggreko.com
and Squeeky is none to please about a porsche or should i say porsche repairs looming in the near future
post-36964-1204510532_thumb.jpgpost-36964-1204510409_thumb.jpgGOOD TO SEE SHE`S IN YOUR HAND`S :laugh: .Here`s a few of my mate`s giving his a work out at the local track (wanneroo&ahg),He`s now getting some new bit`s for his,I will get some better photo`s if he will clean her .cheer`s chuckie.
Hmmm Chuckie,
does your mate want to sell it LOL!
Just in case you didnt know this is a 964 turbo S model only 80 or 82 made Some debate over the figure. This is one of the rarest porsche made! Please check and let me know what color the intercooler is, would be cool to know there is one in OZ
Comes with a modified 3.2 litre 380 hp turbo engine not the 3.6 as in mine but more than made up for by the car weight being much lower.
and a link to check it out on
http://www.rennlist.com/
And just in case if it is a real one then there is only one other for sale in the world i can track down for a cool 261,000 aussie dollars
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
