Hey Guys,
I'm from Brisbane, I'm yet to track down an owner (or a tuner) that has knowledge of EMU.
I travel to Syd & Melb on a regular basic, and keen to speak to any 34GTT owers that have an EMU installed.
I have a few questions specific to the GTT (manual) installation & tune.
any contact would be great - PM or post here.
:rofl:
https://www.sau.com.au/forums/topic/198735-r34-gtt-running-emanage-ultimate/
thanks Paul, i have sent him a PM.
In time, I'd like to compare maps, settings, etc with other 34 owners.
but obviously the EMU still isn't being used much these days.
still, if anyone knows anyone, send me a pm.
cheers
mavric ;)
^^ will have mine setup for a Feb opening, just waiting on dyno and to finalise some things at the toko autosalon.
sorry Pear i missed your pm, feel free to send you message through to [email protected] but im away from the 10th
Keep us posted!
  • 3 months later...
Hey Guys,
Hey Guys, still haven't spoken to anyone with an emanage installed in an R34 GTT. Anyone?
do you guys have any rough rwkw numbers, in terms of 'increase'??
ie, manual turbo, basic mods, say... full 3" exhaust, maybe an intake mod... what would the EMU upgrade be getting the power to roughly?
cheers,
daniel
cheers,
daniel
No different to any other ECU mate
190-200rwkw for a stock turbo'd car.
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
