Wiring an Amp in a R33
Guest thfc1afc0
To anyone who has an amp wired up in their 33, is it earthed to the battery earth or has it got it's own earthing point ? If so where is it ?
I wouldn't have thought it would make that much difference, but really don't wanna fry my amp after spending the best part of a day creating a custom unit to fit next to the battery containing my amp and multichanger.
Cheers
G
https://www.sau.com.au/forums/topic/19893-wiring-an-amp-in-a-r33/
yeah i did all that myself, the battery is still in its original position, the hicas computer was moved to the middle of the parcel shelf to fit the speakers in. They are alpine type r 6 by 9's in for rear fill, Type r 6 1/2 splits up front Type S 12 subs with and Alpine MRV-F540 and an alpine MRV-T420 powering it all. The amps are located behind the subs on a piece of mdf mounted on the fake partition in the 33 boot. The grey u see is just a vinal trim piece and the box isnt much bigger then the whole cut out for it. and the base of the box is just 19mm mdf the is much longer then both sides of the box so i had somewhere to screw the bow into the floor. It takes all of 5 mins to remove so i can still get to the spare tyre.
  • 1 month later...
NA_R33 i like the sounds of your system, at the moment I have a M500 mono block running a 12" JBL Powerseries, i have type r 6 1/2's in the back, F#1 Status splits in the front, 307 running all the speakers, alpine tv and vcd changer, and sony PS2, and a stinger capacitor. i am looking at going to 2 jbl's and a m1000 (around 1200 watts rms) and a new alpine 4 channel. I had type r splits and loved them, but after going to the F#1 Alpines i would never go back.
the dual voice coil type s is a very good sub for its price, If you are willing to spent a little extra the type r is a very good choice. I had a type r and it really went off, but the JBL is just that little better. I put a type s in a mates corolla with around 200 watts rms behind it and it goes of its head, he got the sub and the m200 amp brand new for about $450, and it really does sound good.
dude your whole chassis is negative, so you can ground your amplifier to any conductive material that is attached to your chassis, it will carry negative energy, when 'blowing' things up it has to have a power current running through it thus the need of positive but you counteract such things buy having inline fuses.....
-bryan
  • 1 month later...
BryanB,when grounding an amp which is close to the battery, it is best to connect the amp to the -ve terminal, or the same ground point. The reason for this is that by grounding at another point nearby can 'induce a ground looping inductance', which can leak signals back into the amp and cause interference. If the battery is a long way away, then there is little chance of this and a different grounding point is unlikely to cause a problem. I got this info first from my old man, and backed up by ppl at DLS.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
