Wiring an Amp in a R33
Guest thfc1afc0
To anyone who has an amp wired up in their 33, is it earthed to the battery earth or has it got it's own earthing point ? If so where is it ?
I wouldn't have thought it would make that much difference, but really don't wanna fry my amp after spending the best part of a day creating a custom unit to fit next to the battery containing my amp and multichanger.
Cheers
G
https://www.sau.com.au/forums/topic/19893-wiring-an-amp-in-a-r33/
yeah i did all that myself, the battery is still in its original position, the hicas computer was moved to the middle of the parcel shelf to fit the speakers in. They are alpine type r 6 by 9's in for rear fill, Type r 6 1/2 splits up front Type S 12 subs with and Alpine MRV-F540 and an alpine MRV-T420 powering it all. The amps are located behind the subs on a piece of mdf mounted on the fake partition in the 33 boot. The grey u see is just a vinal trim piece and the box isnt much bigger then the whole cut out for it. and the base of the box is just 19mm mdf the is much longer then both sides of the box so i had somewhere to screw the bow into the floor. It takes all of 5 mins to remove so i can still get to the spare tyre.
  • 1 month later...
NA_R33 i like the sounds of your system, at the moment I have a M500 mono block running a 12" JBL Powerseries, i have type r 6 1/2's in the back, F#1 Status splits in the front, 307 running all the speakers, alpine tv and vcd changer, and sony PS2, and a stinger capacitor. i am looking at going to 2 jbl's and a m1000 (around 1200 watts rms) and a new alpine 4 channel. I had type r splits and loved them, but after going to the F#1 Alpines i would never go back.
the dual voice coil type s is a very good sub for its price, If you are willing to spent a little extra the type r is a very good choice. I had a type r and it really went off, but the JBL is just that little better. I put a type s in a mates corolla with around 200 watts rms behind it and it goes of its head, he got the sub and the m200 amp brand new for about $450, and it really does sound good.
dude your whole chassis is negative, so you can ground your amplifier to any conductive material that is attached to your chassis, it will carry negative energy, when 'blowing' things up it has to have a power current running through it thus the need of positive but you counteract such things buy having inline fuses.....
-bryan
  • 1 month later...
BryanB,when grounding an amp which is close to the battery, it is best to connect the amp to the -ve terminal, or the same ground point. The reason for this is that by grounding at another point nearby can 'induce a ground looping inductance', which can leak signals back into the amp and cause interference. If the battery is a long way away, then there is little chance of this and a different grounding point is unlikely to cause a problem. I got this info first from my old man, and backed up by ppl at DLS.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
