I'm gonna be at Hot BBQ next to Federation Square on the Yarra on New Year's day, so will be having a quiet NYE, probably at some mate's house party or soem shit.
But come check out Hot BBQ... tickets are still available (unlike Summerdayz):
http://www.futureentertainment.com.au/Even...08_webpage.html
https://www.sau.com.au/forums/topic/198964-new-year-plans/
I have an invite to the Groove Armada and Sneaky Sound System beach party in Sydney but not sure whether to go, might just stay locally.
no way, go for sure!!
Im going to be down at my beach house in blairgowrie, although may head down to Sorrento or Portsea.
https://www.sau.com.au/forums/topic/198964-new-year-plans/#findComment-3549555
Hmm I'm gonna be staying at Portsea in the new year. Havent seen many skylines down there before, mostly x5's and cayenne turbo's... Wonder if i'll spot your ve hic cal.
https://www.sau.com.au/forums/topic/198964-new-year-plans/#findComment-3549793
Dont think ill be doing much driving... mainly just drinking. But ill prob be down that way a little.
https://www.sau.com.au/forums/topic/198964-new-year-plans/#findComment-3549804
I don't know where I'm ma going to go.... everything (most things) are closed.... say, does anyone know where I can get some sand paper like today?? Just need like 2 pieces to sand down my front bar and repaint... sick of the matt black look... wanna go matching paint and want to also patch up a fill cracks...
Anyone got some that's from the Western suburbs? Thanks.
https://www.sau.com.au/forums/topic/198964-new-year-plans/#findComment-3550115
I'm going down the G/F's beach house in St Leonards, big family event, should be fun :)
Spunky - You don't really wanna sand down a bar with sandpaper, will take for ever and end up fairly average, you need to use an orbital.
https://www.sau.com.au/forums/topic/198964-new-year-plans/#findComment-3550141
LoL random...but ye i have some at home, im from the west
https://www.sau.com.au/forums/topic/198964-new-year-plans/#findComment-3550284
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
