hi guys,
as everyone seen so many front end conversion... like..
- R32 with R34 front
- R33 with R34 front
- 180SX with S15 front
- S14 with S15 front ect..
I'm thinking about doing my R32 front end coversion but!.. I want S15 front on my R32 ..
so, does anyone have seen this conversion before? what the dimention of the S15 front compare to R32 (gtst) front? are u reckon this is gonna be hard or impossible to do? where should i get this conversion done?
PS: just an idea, not 100% sure if i wanna do it ??
Cheers
https://www.sau.com.au/forums/topic/199067-front-end-conversion/
  • Replies 49
I've seen a 32 front on a 180, so dimensionally i think you should be ok.
The only concern i can think of is bonnet to cam cover clearance at the front of the engine as the s15 looks to have a more pointed front end.
But! Personally, i think the s15 front only looks good on 180's and s15's. The r32 is very similar in styling to an s13 silvia and the boxy angular back does not match the more rounded front IMHO.
34 front works on a 32 (and s13) as they both have that angular look to them
Edited by BHDave
It would be interesting to see what the S15 front would look like on an R32, but I wouldn't do it. Everyone having front conversions are doing it to S15's. WAY too common. Maybe S14a front conversion? Or 180 front conversion? Everything's going to be custom anyway so might as well change it into something others usually don't.
There's a S14 with a 180 front here in Melbourne done by Vu and his shop and it doesn't look too bad.
I think you should (if you have the time, a good panel shop/mechanic etc and the money) go R34 front on a R33 GTR body.
Perhaps this will give you some inspiration:
http://www.skylinesaustralia.com/forums/R3...51#entry3551451
Find someone who is good at photoshopping and get them to photoshop an S15 front end onto a photo of your R32. That way, we can all see what it will look like and go from there. I think It'd look weird, but it could work. Up to you. But what about a 180SX front end? Or something outside the Nissan camp altogether?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
