Hi,
I was wondering if anyone knew of any other suspension products on the market (besides Tein EDFC) that allows for damper adjustable settings in the car? This is for an R33 GTR. I have searched around a bit but seems most of the in car adjustable gear is made for newer model cars and mostly overseas models. If they are not available from the major manufacturers, does anyone know if there are places that do custom suspension with custom in-car controls?
Thanks
Greddy are having a promotion with AUTOBARN this month where you get free in cabin damper adjustment with all TYPE-s coilovers.... i think the container i ordered was landing on the 1st of jan... give any store a call. i can no longer help though as i resigned a fortnight ago :D
Hi,
Thanks
Hi Mark, before you go ahead and waste your money, do you know what adjusting the damper rates actually does? Do you know what you are actually adjusting? Bump, rebound, both? If both, then in what ratio? Which way do you adjust them to overcome some low speed understeer? What about high speed oversteer? Do you really think that changing the rebound damping, on end or both ends, will affect the overall handling balance? Perhaps you think that soft for street is the go and then hard for track? What if that isn't right?
If you don't know exactly what you are doing, wouldn't you be better off with a shock that has a large window of operating efficiency so that you don't have to adjust them?
Happy New Year
Gary
Happy New Year
Gary
Thanks Gary, thats good food for thought..
I used to have HKS Hiper-D coilovers, they shook the car too much and used to bounce around too much even on the softest setting. Now have Bilsteins with King Yellow springs (rate unknown). The Bilsteins seem firmer yet more comfortable and handle better but still get a lot of bounce going on so sometimes I wish I could just make it a bit softer at times to handle the crumby streets. I suspect the springs are too stiff so investigating that first but just thought as a possible alternative going with a decent coilover with an in-control unit that can make it easy to experiment with.
All in all, just checking all options and doing some research first before taking it to a suspension place as I am certainly no expert in the field :thumbsup:
My mate has Trust/Greddy Shocks and his car is the worst riding car I have ever been in, it jumps all over the road at highway speeds, and at low speeds it shakes your teeth out.
They were put on by the pevious owner in Melb (so not old slogged out Jap 15 yo ones). After experensing them I would never even think about trust/greddy suspention.
Oh Darn. I just ordered the Type-S from UAS - so no free in car adjustment for me.
Also check the spring rates. Mine are for a R33 GTR. They come in two spring rate options. I went for the 8F 6R option but you can get a 12F 10R. Sounds like the previous post had the latter.
All in all, just checking all options and doing some research first before taking it to a suspension place as I am certainly no expert in the field :banana:
In the case of most Jap shocks you are only adjusting the rebound damping, hence it will make absolutely zero difference to how harsh it is on impact. All you are adjusting is how fast (not how far) it will recoil after the impact. Some adjusters (very rare) do both rebound and bump, but in a fixed ratio, generally between 10 (rebound) to 1 (bump) and 5 to 1. So they also make very little difference to the impact harshness.
By far the spring rate has the most effect on harshness and keep in mind that the standard springs are around 3 kg/mm. R32/33/34 Skylines are sports cars, so they don't have "soft" spring rates to start off with. What effect do you realistically expect when you are more than trippling the spring rate? A 10 kg/mm spring rate is still going to be a 10 kg/mm spring rate no matter what you do with a shock adjustment. Reducing it by 20% (to 8kg/mm) is hardly going to make a discernable difference.
What's the best spring rate? If you aren't going to lower the car and only use it on the road, then the standard spring rate is pretty much spot on. If you are going to lower it, then the ratio of 20% lower to 20% increase in spring rate is logical. If you are going to use it on the track then ask the tyre manufacturer what effective spring rate they suggest for your selected tyre. You will be hard pressed to find any "R" type tyre that will tolerate an effective rate much over 5kg/mm. As for a road tyre, then 4kg/mm is the maximum I have seen for a tyre that will fit a Skyline.
Happy New Year
Gary
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
