So SK. Assuming you had a regular 2.5L normal cams etc would you recommend the vg30 housing in order to get ~ 250rwkw.
Should the response still be ok? Putting your invested interest aside hahaha
What I'm wondering is if is worth downgrading to the R33 cover to increase response and still have close to 250rwkw. It's about 4-6 hours work taking the turbo off and on again though.
Nope, the high flowed RB25DET turbine housing will do 250 rwkw, givne decent tuning.
Personally I wouldn't use a VG30 turbine cover until I was aiming for 275 rwkw or more.
Why have the poorer throttle response when you don't have to?
Cheers
Gary
Just swapped back to the smaller cover.
Quite a large improvement in boost response. Admittedly the comparison was on the untuned map for both turbos (so the difference may be reduced with a proper tune).
Its strange the r34 runs the larger cover. The r34 must spool a little later than the r33 (I guess stock they have the smaller lighter wheels so less noticeable)..
Much happier with it now though. I should have probably kept the vg30 cover in case I ever go 3L bottom end though :laugh::(
Edited by benl1981
Chris. It really transforms the car. I didn't enjoy driving it that much with the vg30 housing. Now it is just always there ready to start going.
Slightly laggier than stock turbo but not much.
Peak Boost probably made 300-500rpm lower but it is the ease with which it builds the boost that is important. You really had to sink your foot into it with the vg30 housing, now you can get 6psi+ without hardly any throttle input.
Unless your willing to spend money on cams, or cam gears or 3L etc I wouldn't recommend the vg30 cover. Will be a lot of tuning to get it close to the r33 housing response.
My car is 99% street driven so it is important to have the low end. It's never going to be a v8 but anywhere over 3000rpm is great now..
Edited by benl1981
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
