Yeah ive bought dont forget 10day freight adds a good $100 roughly and currency conversion changes dramatically and credit card usually add on 3%
Sending via Bank cost me $38
Receiving at nenguns Japan bank cost ME another $33
So now u know why japan is cheaper and dont forget that is WITHOUT any GST
You can trust him i did :-)
What I have been doing recently for AUS customers is letting them pay into an AUS account if the part is under $500 AUS that way it does away with the international bank charges.
Hey Macka. How much GST did you pay on your parts?
I didnt pay any GST it wouldnt of been worth it otherwise......
All GST is 10%
Nengun i did send you an amail saying thankyou and for somereason it came back to me saying email had expired and was returned??
Anyway you did good and my car is running sweet now so thanks for your help mate
mac
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
