  • Replies 3.9k
Posted Images
The appearance of Ferrari's radical new nose innovation at the Barcelona test on Monday confirmed that espionage could still be a factor at the Italian team.
Alleged Ferrari spy Nigel Stepney no longer works for the Maranello based team, but the technical secret about the 'hole nose' nonetheless emerged in the pages of an Italian magazine some ten weeks ago.
Autosprint broke the story about the nose, including sketches of the innovation, in its pages in February, raising suspicions that the leaking of confidential and sensitive design data has not stopped, notwithstanding Stepney's firing and McLaren's $100m fine.
According to the Swiss newspaper Blick, Technical Director Aldo Costa was 'horrified' about the leak, confiding that 'very few' Ferrari workers even knew about the nose solutions when they were being tested in the wind tunnel.
Blick claims that an internal investigation into the leak is in progress.
awesome
Who cares the soft tyre is just a diversion from the fact the racing is so dire. Just gives people the false hope that someones option tyre will grain & stuff their race.
Bin refuelling.
Give em soft tyres that only just last the distance.
Kill the downforce.
Then we may get some racing.
they should never have left
how do they intend to mark the softer tyre since there will be no groove in the face of the tread to paint on that rediculous white stripe?
Well yes... Exactly...
I'd still like to see a ban on all those silly flaps and elements that protrude all over these modern cars, reduce some of their aerodynamic efficiency and make it so a trailing car gets a bit of tow... Also, I'd like to see F1 take the biofuels route... 1.8 litre turbocharged V8 biodiesel motors... Could you imagine the torque??? :D
Why do people keep winging about parity in f1? It’s the pinnacle of motorsport, why should they have restrictions? The cars should be using the best and most advanced of everything that they can come up with. If a team is loosing then they need to make a better car or continue to loose... If people say "to keep the cost down" well if you want to play at the top then you need to bring the appropriate $, why should other teams who can afford the development suffer for the team that wants to play the game but cant really afford it....
F1 should not be about making all cars even, it should be about the ultimate speed whatever way possible.
FINALLY!
Unfortunately there arent enough companies/car makers willing or able to spend the big bucks to complete like the top teams are doing. By cutting costs it allows more teams to entry into this business, because without any cars on the grid to watch, theres going to be no formula 1 to watch.
F1 cars these days now exceed the limits of the drivers ability, not the other way around which was the cse in 'the good old days'. So now they are having to regulate the cars so as to keep them at a level where both car and driver abilty are somewhat the same. With this comes ridculous rules and band aid solutuions to the ever growing list of pronblems. And when you have dipshits like Mosley in change of these things, we're never going to get real solutions
So once again, thank you NoW... you've done us all a great justice
Edited by ctjet
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
