  • Replies 3.9k
Posted Images
Go Bourdais, i think i am the only bloke that likes the guy....and really want to see him get a good result. It seems he needs it to retain his seat.
Hamilton has some work to do.....and i miss commentary by Brundle. I have Bailey commentating, couldnt drive his old Tyrrel, cant commentate either :)
THATS WHAT IM TALKIN BOUT!
lol
he sounds like a brother with no soul when he said that. the high pitched english accent just doesn't sound ghetto.
the weather came to him right on the button.
Heidfeld the sneaky bugger comes thru...again.
the driver of the race for mine was Massa. very wet track and no spins or crashes!! :)
Edited by wolverine
He drove well and took advantage of the weather. He is a massive tool, and it pains me that it looks like he will win the WDC from here unless Ferrari can bag a few 1-2s.
Good work by Nick, he stands out as the best racer on the grid, and again scores some very sneaky points. Poor Bourdais, from 3rd to 7th in a few corners :)
And, it was a very cunning move by Lewis on Kimi, but is it legal? I mean the move around the outside gave him the advantage and run at him for the next corner??? But its for nothign anyway as i think Kimi thought he could defend the position to the flag and didnt react to the laps Lewis was running at.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
