  • Replies 40
to flush the radiator u dont neeed to remove it. just d/c the top hose and then the bottom hose. put a hose in the top and flush away. after that flush the engine by sticking the hose into the intake (top hose) and allowiing the watr to come out the bottom.
It will work better if you "reverse flush" the radiator. By adding water in the top, all you are doing is forcing the crap further into the cores.
Take it out, upend it and push water in the what is normally the bottom of the radiator.
hopefully have fixed my overheating probs will find out when i put the rad back in the car on the weekend . took my rad to work and sent it of to the guys that do our rads for our work . turns out it was about 40% blocked and the top tank wasent the best adding to that my thermostat was not working properly hardly operning in a boiling saucepan of water hopefully it's sorted .
on the other hand tonight my sons r33 looks like it has blown a hose behind the head somewhere will bring the pressure tester home from work tommorow and see what going on there .
this hot weather in adelaide is taking its toll atm . we have so many people phoning and driving off the street for aircon regass it's running us off our feet good for the boss i supose tho lol
and the funny thing is when its 30 degrees and i turn the a/c on after awile it overheats
if its 25 degrees outside i can turn the a/c on and it wont overheat
but when its 35 and over without a/c it overheats lol..............strangeeeeeee
not strange at all, the AC makes the motor work harder, the air con core in front of the radiator gets hot, and pases the hot air onto the radiator, theres extra heat under the bonnet... all taking its toll on the cooling system. If part of the cooling sys isnt working properly, then it all goes down hill.
well... well... the boys at thommo radiators found that my radiator was leaking pressure on the bottom of the seems
on order is a Just jap aloy radiator hopfuly there good i didnt want to spend 800 bucks for a genuine nissan one
Edited by Jsikalias
Yeah I've got one of those from fatz.. had two tiny pinprick leaks on the upper front corner (in the welds) which I wasn't very happy about but not much I could do, just put some silicon on them and she'll be right.
I am however having slight over heating problems under certain conditions now that I didn't have before, new thermostat, water pump and radiator cap on their way so I'll put those on before I make any claims about the radiator. Most others have good experiences so I hope that it's the water pump/thermostat/radiator cap that is the cause and haven't wasted money on the radiator.
whooo hoooo all fixed took it for a spin today up the hills with the aircon on it's another stinking hot day in adelaide and the needle sat a fraction just under half and did not move at all . cleaned out rad and new top tank . new thermostate . flush all old coolent out and replace with new total cost around 200 bucks . im as happy as a pig in poo .
found the problem in my sons car why his overheated it has split the turbo water line behind the head looks loke a prick to get at and fix .
bugga he can wait till the weather cools down lol mines fixed thats the main thing lol
cheers mid life crisis
Whereabouts would i be able to get a new radiator cap for my car? what specs or part no. should i be looking for? Cheers...
i think you would have to get a new cap from nissan i think thats where i would go just to be safe
hey atleast you knoe you have the correct cap then
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
