my liver still hurts from my nye + nyd bender...
i blew a .604 at the end of nyd......
what is classified as dead???
:yes: you would have to drink almost a litre of spirits in an hour to get that sort of reading
man, no way can you be conscious and blow .604. you must have dribbled some beer straight into the tester! I would need I reckon about 80 beers to get to .6 and I would be passed out long before i finished drinking them.
thats my proof....
id stopped drinking about half an hour before and was on the waters for a bit as i had a really dodgey burger for dinner..
wont make an appearance tonight, my sister has some friends over and is cooking a massive feed and producing cocktails.... next thurs might be a different story though!
sorry lads- the drinking boots had to stay in the wardrobe tonight- had some other stuff on.
plus i'm still in training on a stunt to top last time's pokie crashing efforts :down:
when's the next round planned?
One of the many entertaining stories i heard tonight lol
By the way my friend who was with me"Matt" pulled 1300 out of the pokies WTF!
shit an he bought us one drink
tight arse!
nice plether in the daewoo
thanks for the llift and them kebabs roc!!!!!!!!!!
wasnt the same without you kell!
plus i'm still in training on a stunt to top last time's pokie crashing efforts :)
lol, I thought maybe you were still grounded. ;)
yes top night and good company. turnout was a little weak but never let that get in the way of a session. next event will probably be 2 weeks from now. or we might make it 3 weeks from now to get back in sync with our normal time. :huh:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
