rich flavour Posted January 5, 2008 Share Posted January 5, 2008 (edited) Hey all, i have just installed this kkr 480 turbo i had at home. i have found that for some reason even with the actuator rod not connected the car still running boost, i guessing the size of wastegate hole is to small..correct me if im wrong??? has anyone had this problem?? also have i got the kkr430 and maybe this is the problem ?? but im 90% sure its the kkr 480 someone gave it to me so... cheers. Edited January 13, 2008 by rich flavour Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/ Share on other sites More sharing options...
paulr33 Posted January 5, 2008 Share Posted January 5, 2008 with the actuator disconnected, the wastegate will never open, which means boost will continue to rise as long as the throttle is open and the engine is ingesting air this basically means your running unlimited boost - be careful with this - it might go bang. what spring are u using in the actuator? what boost controller have u got setup? what exhaust setup do you have? have you checked the actuator / swing valve for play? does the wastegate flap actually open? Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564299 Share on other sites More sharing options...
R334door(s2) Posted January 5, 2008 Share Posted January 5, 2008 Hey all, i have just installed this kkr 480 turbo i had at home. i have found that for some reason even with the actuator rod not connected the car still running boost, i guessing the size of wastegate hole is to small..correct me if im wrong??? has anyone had this problem?? also have i got the kkr430 and maybe this is the problem ?? but im 90% sure its the kkr 480 someone gave it to me so... cheers. youve gotta get it machined out mate to a bigger wastegate hole and flap MTQ doit or any other turbo place i had to doit to my kkr430 Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564303 Share on other sites More sharing options...
l0WRB Posted January 5, 2008 Share Posted January 5, 2008 i also get the same problem my kkr480 i just had it put back onto my rb25 and i also put on a greddy plenum and last nite i seen 1.46 bar so that cant be good hmmm b4 the plenum upgrade it was around 1.2bar i would hit... Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564324 Share on other sites More sharing options...
drmafia Posted January 5, 2008 Share Posted January 5, 2008 i had same issue with 480, even tho we unwlded the gate n changed it, so i took off the turbo. it didnt make the power i was after anyways and was runing way too high boost 23psi ish to make only 290hp to the back Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564380 Share on other sites More sharing options...
l0WRB Posted January 5, 2008 Share Posted January 5, 2008 sounds a bit like my issue lol 2 much boost for f**k all power.. typical kkr Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564387 Share on other sites More sharing options...
drmafia Posted January 5, 2008 Share Posted January 5, 2008 im sellin the kkr setup soon and im selling a real good Greaddy td06h-25H polished turbo with top mount mani and gready dump pipe, if u want this will spool fast n pull very hard all the way unlike the kkr that kickes in way too late on such high boost.. let me know if intersted Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564451 Share on other sites More sharing options...
rich flavour Posted January 5, 2008 Author Share Posted January 5, 2008 with the actuator disconnected, the wastegate will never open, which means boost will continue to rise as long as the throttle is open and the engine is ingesting airthis basically means your running unlimited boost - be careful with this - it might go bang. what spring are u using in the actuator? what boost controller have u got setup? what exhaust setup do you have? have you checked the actuator / swing valve for play? does the wastegate flap actually open? The spring on the actuator is factory kkr, exhaust 3inch after market turbo back. i have checked the actuator it functions fine, tryed with 2 diffrent boost controllers one electric the other just a cheap t piece style same resault. i have also tryed with no boost controller does anyone no the least boost you can run with this actuator?? so wastegate hole is to small thats my problem? Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564681 Share on other sites More sharing options...
rich flavour Posted January 5, 2008 Author Share Posted January 5, 2008 im sellin the kkr setup soon and im selling a real good Greaddy td06h-25H polished turbo with top mount mani and gready dump pipe, if u want this will spool fast n pull very hard all the way unlike the kkr that kickes in way too late on such high boost.. let me know if intersted How much you want for this turbo mate? what state you in? how manys k's has it done? and at what boosts? what sorta power can i expect to make at the wheels?? Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564687 Share on other sites More sharing options...
rich flavour Posted January 5, 2008 Author Share Posted January 5, 2008 i also get the same problem my kkr480 i just had it put back onto my rb25 and i also put on a greddy plenum and last nite i seen 1.46 bar so that cant be good hmmmb4 the plenum upgrade it was around 1.2bar i would hit... what do you rev your car out to or you dont flogg it when it isn't running right? Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3564693 Share on other sites More sharing options...
l0WRB Posted January 5, 2008 Share Posted January 5, 2008 limiter is set to 7500rpm im pretty sure, but since plenum upgrade and car hasnt been tuned, ive lost alot of down low and turbo comes on really hard bout 5000rpm and then goes straight to limiter... Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3565110 Share on other sites More sharing options...
rich flavour Posted January 6, 2008 Author Share Posted January 6, 2008 limiter is set to 7500rpm im pretty sure, but since plenum upgrade and car hasnt been tuned, ive lost alot of down low and turbo comes on really hard bout 5000rpm and then goes straight to limiter... sounds gay if the boost range is 5000 to 7500rpm is it evan worth it? Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3565729 Share on other sites More sharing options...
l0WRB Posted January 6, 2008 Share Posted January 6, 2008 i like it lol standard response gets old real quick, plus u cant drive around off vacum or hearing ya turbo spool, but wit a bigger one its nice u can just cruise round and yeh ... Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3565735 Share on other sites More sharing options...
R31Nismoid Posted January 6, 2008 Share Posted January 6, 2008 It would make the car slower than if it had the factory turbo i reckon. Useless powerband Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3565811 Share on other sites More sharing options...
Al Posted January 6, 2008 Share Posted January 6, 2008 KKR turbos are nothing short of shit................. You get what you pay for; and a little less with the kkr Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3566079 Share on other sites More sharing options...
rich flavour Posted January 9, 2008 Author Share Posted January 9, 2008 It would make the car slower than if it had the factory turbo i reckon.Useless powerband Factory turbo is faster untill the kkr turbo comes on boost then she will scream past.. Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3571616 Share on other sites More sharing options...
l0WRB Posted January 9, 2008 Share Posted January 9, 2008 haha yep, nice top end, most 200rwkw skylines will smoke other hp cars on the street until bout 120 then u get traction and start reeling them in big time haha Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3571733 Share on other sites More sharing options...
rich flavour Posted January 9, 2008 Author Share Posted January 9, 2008 hey |OWRB do you run 1.46 bar boost still with no problems? i have found it to lag a bit and then come on real hard almost too hard. Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3571753 Share on other sites More sharing options...
N I B Posted January 9, 2008 Share Posted January 9, 2008 Ive had to fit Exturnal gates to save these crapper Turbos. Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3571764 Share on other sites More sharing options...
Al Posted January 9, 2008 Share Posted January 9, 2008 Factory turbo is faster untill the kkr turbo comes on boost then she will scream past.. Not before the finish line The other car will have the beers open an waiting for you, while you wait for boost Link to comment https://www.sau.com.au/forums/topic/200257-kkr-480-on-r33/#findComment-3571880 Share on other sites More sharing options...
