Item:ROH Drift R Wheels
Age:1year
Condition:bit of black stuff from brakes on front wheels(about 4 dots),90% tread as i drive it once a week at most.
Price:$1200
To Fit: (What car) 5 stud 114.3 skylines,200's,falcons,hillux
Contact:PM Me
Comments:265/35/18Rear & 235/40/18Front Firenza ST-03 tires with even wear.90% tread left.
heres some pics
Edited by FATAZZ
https://www.sau.com.au/forums/topic/200263-roh-drift-r-wheels/
  • Replies 57
swap for my 18's?
No thanks,Gone back to 16's and sticking with them.
Want these gone,or traded for other car parts.
EDIT: i actually cleaned 99% of that brake dust off too. can hardly see it at all.
bout 4 dots of black stuff left tiny tiny dots
Edited by FATAZZ
Thanks heaps Adriano. ill do that.yeh they look good,made my car look tough as but im keeping it stock.
Cheers
Hurry up peoples,Like Adriano said its a good deal,im going to put them on a few other forums now.
Bumpski!
Edited by FATAZZ
hey i bought my R33 from the yard it had these rims in 19s looked fkn phat very JDM i must say...... full GTR kit and gold 19's looked alright...... but i went all bling bling....... then got defected now back to 18 inch enkeis real JDM YO! lolz
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
