  • Replies 44
They rank up there with fake bov's... but if you're dead set on looking like a tool, goto any nos or nxexpress installer and ask them to hook you up with a CO2 rather that Nitrous Oxide purge kit.
Might as well go all out get the Nitrous Oxide nozzles installed and a bottle warmer, at least it won't be all show then >_<
he didnt ask you what you thought of it. Or your flaming.
He just asked where he can get it from..
All of you guys just jump on the bandwagon and start flaming because YOU think it's gay.
tis called freedom of speech my friend, maybe we could talk some sence into him
he didnt ask for your particular opinion on flaming in this thread either but you still gave it
lol
install a t-piece on your radiator hose. install a thin heat resistant tube into said t-piece. run this tube into a windscreen washer nozzle. drive up and down the road at really high revs till your engine's really really hot. activate nozzle. watch as your ghetto fake NOS inflicts damage to your car's paintjob and delivers amazing 3rd degree burns to your face. it'll cost you about $20 in supplies. good luck.
fknlol! :woot:
LOOOL :P
is it that bad??
woops, i didnt know... lol...
I was just thinking of the 2F2F movie, and finally found out what those systems are called. :D
From what i know the only point of a purge valve is to purge air and vapour out of the lines so that the liquid nos fully fills the lines... Its basically only used (properly) by extremely high end drag cars which need every last bit of performance.
Most people who are into performance cars know this, so therefore when they see a dude in a stock looking R33 purging what appears to be nos, they instantly think -POSER- Your car doesnt need that mod for any reason other than to try to look cool.
To make matters worse, you're talking about putting a FAKE version of a pointless modification onto your car. Thats twice as bad! :banana:
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
