my boss owns one and has had soooo many electrical problems with it over the years. i guess the more automated gadgets on board, the more things to go wrong
Yeah I have seen some problems with the electrics, and the gearbox in them fails sometimes.
I was considering purchasing my uncle's one when he put it up for sale, lucky I didn't because 2 months after the sale gearbox went pop 12k repair bill. OUCH!
  • Replies 46
Thanks for all your opinions guys.. really appreciate it. But don't really want to go too Grandpa-spec with the bmw/mercedes sedans or even EVO's or STI's as im after a sports coupe.
Well at this stage i'm still unsure of what to get but i may have to test drive a r34 gtr as 90% of people i know are telling me to get one. But too me its still a another skyline.
But right now i'd have to say its either between the NSX or the 350z..maybe M3 e36 but still unsure.
What are your opinions on the NSX as i've yet to drive one, and how would you compare them to say the BMW M3 or R34 gtr.
Thanks guys
EVO? 930 Turbo porsche?
Hey Musty! yeah the EVO is a 4 door..and don't really want another 4wd turbo.. as you may already know
930 Porsche on the other hand, looks abit old. Although wouldnt mind that Ferrari you have.. :banana:
Tai cant believe ur considering of selling ur r33, u just finished it! Outter ur list i would go for any of the first 3.
Yeah Ferah sought of getting over the good old skyline. But im unsure of which one to sell, but most likely its the R32 GTR.
Want something with abit more respect and not so common.
get yourself a BF typhoon. bout 40-50k.
or vy-vz senator in black.
but if u want to stick to a jap car id go the 350Z with mods :P
Not a big fan of Aussie muscle cars, although they do look quite mean. I'm soughta after a smaller, lower 2 door car..if you know wat i mean.
Thanks anyway.
the ferraris mine all mine :D
what about an s2000? not a turbo but sooo much potential
Booked for a test drive in a silver R34 GTR from Gran Turismo (GTA) in city this weekend. Want to see what all the fuss is about, but still curious to see or drive a NSX.. anybody been in one??
As for S2000 a tad small i reckon there almost MX5 like.
I know this is a Skyline forum.. and this may seem like a silly question. But whats better a 95 NSX or a 98 R34 GTR? opinions please.
thanks
Just purely from an eye catching viewpoint, the NSX will grab a lot more attention than 99% of Skylines. Unless you do a GTR up to the same standard as your candy 33.
They look awesome, especially with a nice kit (veilside looks mean). And from what I understand they go pretty damn hard too.
The NSX is a great car. I've driven an early model 3litre manual and they handle well, good torque, nicely balanced and nimble car to drive with a few suspension tweaks. They are very small and low, inside there's not much room at all, but all the controls are within reach. They definitely get the looks.
Snowman owned an auto NSX-T (targa roof) so he may offer an opinion.
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
