Real Time Gps Gprs Gsm Car Tracker Alarm Tracking
  • Replies 107
Posted Images
  • 4 weeks later...
I have a newer & better version now (photo attached, also available in black) with 3 +/- inputs for car alarm alerts/triggers and 1 output with a relay for remote immobilisation as well as GPS last position feature in case it loses the GPS signal (eg. if taken inside a deep underground carpark it will give you the GPS coordinates of the carpark's entrance). As usual, the unit and all the external antennas can be hidden under pretty much anything in your car since they do not need any direct view of the sky.
There's also another type of unit going around which I would not recommend - the all-in-one GPS GSM alarm unit with remotes, this sort of unit is more common and older. It's an all in one car security system without 2/3 point immobilisers (it only has 1 relay that won't even get activated when you press the remote), no all black wiring and/or other features, the security measures are poor and do not meet any standards for a car alarm system. So I decided to get a decent approved car alarm system such as Mongoose m80s that has 3-point immobilisers, all black wiring, code-hopping remotes and other features that meet Australian standards and then added the tracker with its alert features on it. Much better package this way. If I used this all-in-one car alarm system, I wouldn't be able to install a proper and proven car alarm system from a known brand. There's also a cheaper unit with a weaker and less sensitive internal GPS antenna built-in.
Oi! Whats the price for this unit?!
The new unit should now cost around $365, more or less depending on the exchange rate at the time. PM if interested please, and then I'll organise it for you.
Cheers
Edited by gtr_z
This sounds like a great investment to all cars, young or old. free bump, lets see if we can get some more buyers mayb we can get a good price, if not still worth every cent. pm sent mate. :)
:(:P:(
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem. However, before you PM me think about this.
A group buy, is a group of people buying the product together to lower the price.
Buying single units here and there is not what constitutes a GROUP BUY
Thanks
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
