Who can recommend a good brand of weight gloves? My hands are getting cut up due to the new nurling on the bars and attachments.
anything really imo
I used to have leather gloves but they ripped on me (after 5 years of having them mind you) now have the nonslip cloth material ones just because that's all they sold at the gym I go to
went without gloves for awhile coz cbf'd buying new gloves when my other ones ripped but started getting corns where my palm meets my fingers
friday
- have sex
Saturday (if keen)
- just arms, bicep curls, tricep press ra ra
- cardio
- try have sex with the missus LOL
repeat.
that explains it...
try having sex on the OTHER days to compliment your workouts & you'll notice an improvement
I suggest finding other female workout partners if your missus isn't available :D:)
I agree with some_cs_student, John...there's too much isolation going on there, too many exercises...particularly if you want to increase muscle size. And I see a fair bit of crossover in that routine...you should give certain muscle groups a bit more rest...rest is just as important as your workout.
$20-25 fingerless Harbingers from Rebel Sport...don't need anything special in this department. If you go heavy with the weights you'll still get corns with gloves but they won't be anywhere as bad.
On what lifts?
Your hands will get used to it over time, I use chalk for heavy deadlift's.
Although if you never plan on competing in power-lifting or similar than you can get away with gloves...since not using gloves I've found my grip stronger though.
Yeah, not lifting really heavy weights. I think the problem is the nurling, its pretty rippy. Ive actually split the skin on two fingers so I think gloves are the go at least until they fix themselves.
Hrmss.. so what should I be doing? I got some flab on the gut btw.. I wake up seeing a faint 6 but as soon as breakie goes in it's gone...
Any recommendations on the workout? I want to gain some more size & be tone... (I know I know, can't bulk and tone at the same time)
<cut>
Two problems there, your associating your workout with fat loss.
I don't agree with the bulking/toning, have a read of The Truth About Bulking
You can gain muscle and look more toned at the same time, its just hard to do. In fact, I don't agree with bulking/cutting cycles at all, have a read of The first 5 years
PTC - 10 GREATEST FITNESS/STRENGTH MYTHS read number 9 in particular.
Finally maybe try a beginners program?
Quoting Markos from that article "You are a beginner if you cant bench 100kg, squat 140kg and deadlift 180kg. I dont care what your bodyweight is, get bigger, its why your lifting. Bodyweight is not an excuse."
Also see my previous posted link :)
very interesting read!
yes, I am at work, I got in at 4:00 am to do an upgrade on a scheduling system, don't ask lol
Not sure if my routine (on the previous page) is any good though, might need some guidance on what I doing wrong.
  • 1 month later...
Hey all,
Just quickly does anyone know of a decent gym down south, which has free weights and cardio equipment?
Ideally somewhere along the coast between Nowra and say, Ulladulla, so including the Jervis Bay / Vincentia area.
Can't find much online...
Haha yeah, sorry didn't mention that I could be down that way for the holidays for a week or two and would like to be able to keep the routine... there will be plenty of pudding etc to work off :(
I can recommend you DON'T buy harbinger gloves, every pair I've had has ripped in the same spot - down the seam where the tag is on the inside. I'm on my 3rd pair (returned) and I've given up and am using them with gaping holes.
Serious man? I'm on my 3rd pair after like 8 years of training. I buy the cheapest Harbingers too :(
Are they tight or loose when you wear them? Gym gloves should be fairly loose...I see alot of people at my gym with snug fitting gloves and IMO this restricts movement and breathing. You can hold a pair of sponges and use them for grip, so gloves certainly don't need to be tight.
I got a set or urban Muscle gloves, fit good. I only using them on the rotating bar and for seated rows. ive used the Urban Muscle protein powder too, delish and gots the goods.
Serious man? I'm on my 3rd pair after like 8 years of training. I buy the cheapest Harbingers too :/
Pink sponges definately... work the best. :(
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
    • Hi guys,  I just replaced my pads with blue stuff and flushed fluid. The pedal and brakes feel fantastic but I'm getting very slight pedal stutter under any kind of braking. Not every time, maybe 1 in 10 and not under any heavy braking, mostly occurs as I'm reaching a stop. It feels like abs engaging but it's so fast, there and gone in under a second and no abs flash on the dash.  Any ideas what could be causing this?
    • How does dead head help with emissions? Is it being claimed for emissions because fuel in the tank isn't being heated up by being pumped around, hence should condense more? One part that is a negative about dead head is heating the fuel at the rail a lot more (IE heat soaking at traffic lights) and this causing lean outs on takeoff afterwards. If my thoughts above are correct, I wonder how different the tail pipe emissions become with the lean outs vs less fuel tank emissions into a charcoal canister
