id get an adjustable bench so you can do incline and or decline.
dips are a good idea as well. would also be interested to see their pulley system as it could be worth a look at.
quality and price i dont know about.
I would be inclined not to listen to what the side of a protein container says about serving sizes...
of course they are goin to say "take 3 scoops" 3 times a day. They are trying to sell the crap.
figure out how much protein u need a day, usually 1 gram for every pound of body weight (kg x2.2) then use the protein to fill in the gaps between meals, thats why its a "supplement"
Theres no use having a 100 grams of protein in one hit, it needs to spread out through the day
Good point. As with any information you have to consider the source!
I've found 2 scoops of Torrent is enough for me, not the 3 prescribed, especially as I often take Vitargo during the session, so that'd be way too many carbs when taken together.
god damned OS trips... just got back from Thailand for a friends wedding... 10 days spent drinking and eating nonstop and I feel like garbage... fat garbage... just a note, flopping around in a pool/ocean cannot possibly burn off 8 litres of booze and enough Pad Thai to feed every starving child in Africa...
f**k you Ectos...;)
grass is always greener hey... hate having to eat like a medieval orphan but at the same time like it when people stop what they're doing to watch you lift
goal for this year is to have both... look and feel lean while lifting enough iron to affect the earths gravitational pull... after 6 weeks of good work I've fallen off the tracks... weaksauce... time to put down the beer and open a can of harden the f**k up
because your body digests x amount of protein per hour regardless of how much you give it.
So you prefer to load a ton of protein in one meal, and piss out 80% of it instead?? It's not hard to space your protein out over the course of the day.
Why wouldn't you take a slow release protein source before bed? Your catabolic period overnight must be quite significant closedeyes.gif
...I see no logic here
Yea i have no idea what his argument is
anyone here tried doing slow reps? get the set to last near 70seconds. I have been giving it a go and cannot lift near the same amount of weight.
example is for bench 3seconds down, at at the bottom and 1 second up.
recommend giving it a go for a change.
I find slow reps or negatives are both good if you've got a minor injury or are feeling flat and can't push a heavier weight; you can still get an awesome workout while also changing it up a bit and keep the body guessing.
On the protein argument I've also read that those of us who take a lot of additional protein need to make sure we are getting plenty of calcium intake (i.e. through milk, or other sources, in other words check your protein supplement to make sure there is calcium in there as well). This is because the body uses calcium for protein synthesis. You don't want a calcium deficiency.
I never said I loaded up on protein... no shit it isn't hard to space it out over the day, I just said you didn't have to. You don't piss out protein...
Why wouldn't I take "slow release" protein before bed? I dunno maybe the fact that by the time I goto fkn bed I've already hit my protein macros for the day so there's a shitload that will be released over the night.
Dude I suggest you do some research before posting...
"When a high dietary protein intake is consumed, there is an increase in urea excretion, which suggests that amino acid oxidation is increased.."
It depends on the types of protein you're consuming, unless you've been consuming a lot of slow-release proteins throughout the day, your overnight release won't last nearly as long as consuming something like casein before bed (4-6 hours release).
In response to slow reps, I always lower the weight slowly, and explode on the way up. Muscle fibres tear on the eccentric phase (shortening phase), so for example lowering the weight during a bicep curl is more important than raising it.
While on this topic, has anyone here gotten a friend to push down (encourage the negative phase of the lift) on a bar, etc. while you try to resist? It's like super negatives lol, crazy hypertrophy results
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
