if only Princess trozzle was still here.................
she was a good sort, always up for it. ;)
or so i was told..... :P
bahahaha bloody Shell the cruel girl got me good then didn't she...I'm sure if you asked her nicely (or just asked R31Nismoid) they'll f**k my username again for you.
:yes:
well nismo?
so I went down to the PTC yesterday... cool little gym and friendly bunch of people, thanks Markos!
I took it relatively easy as I've never been to a PL comp before and didn't want to embarrass myself... so definitely some more in my squat, and heap more left in the deadlift... totally underestimated how nice the proper DL bar is to use and could've easily gone 200+... maybe next time;)
Squat > 160kg
Bench > 110kg (failed @ 115kg)
Deadlift > 190kg (should've opened with this)
not a bad effort considering I don't train for power lifting... but some super strong guys down there, makes for a humbling experience!
Not sure how to embed video from FB here? can't link due to privacy settings on my FB page
Nick did really well, his only issue was weight selection. His last deadlift of 190kg should have been his opener, I think Nick could have pulled 210kg+
This was a novice comp with mostly first timers, none of the 9 lifters I have going to Worlds lifted, theyre really strong
Nick also displayed excellent technique on all the lifts
As far as equipment goes, nothing better than what we have exists, we have the highest standard available anywhere in the world
The bar they guys benched and squatted with costs $2000, the calibrated plates are $14kg
This is important as we send lifters to Worlds.......no surprises when we get there
Tom, the best gym in the ACT is Elite Physique
They hold numerous comps there. Next one is the GPC National Push/Pull, a bench and dead only comp
This event will be held on the same day in VIC, NSW, ACT, WA, QLD, NT, November 18.
South Australians are coming to Vic to compete this year
Nick missed out on the competitors meeting, I explained we judge hard
Even though its a novice comp, we judge it like a Worlds, no second chances or whoopsies
One guy had his 175kg bench press red lighted because he put the bar back before the rack call
Massive difference between gym lifts and comp lifts
Nick now has official comp lifts to judge his progress by
If any of you guys feel like helping out some of the NSW peeps that would be great.
They have just started a thread for all of them to get healthy.
Seems to be a lack of good info other then exercise.
Drop in and give some tips if you have some free time
http://www.skylinesa...80#entry6495190
***Edit*** Just noticed most of you arent NSW members so it wont let you in
gay
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
