Around 7k
Knew someone would be a smart-ass!
Physio told me I have bicep tendonitis... spewing. So its a few weeks to a month of legs and squats.
Any upper body recommendations that are not going to make it worse while it recovers?
Get into a solid fapping routine. 3 sets of 100 reps per arm.
What do you guys think about home made weight plates ?
I am thinking of designing some in solidworks at work and then getting them lasercut to spec.
Ideas ? Interest ?
Also considering designing my own squat rack and cutting it here.
Sounds like you'll still be able to do pushing movements so triceps, chest, shoulders should all be fine to work.
Ideas ? Interest ?
If you can get them to be the correct weight (like within a gram of each other) then it should be fine.. but also consider that buying brand new rubber coated plates which have handles built in and are the correct diameter and cost about $3 a kilo or less delivered, you'd better be making a decent saving.
As for the rack, I can find you detailed plans of a power cage if you would like.
Any idea of root cause?
My knee tendonitis is actually a combination of hamstring tightness and glute tightness, and maybe the quads are involved too. Either way, if i stop stretching / rolling for any reasonable period of time even without weights I start getting knee problems.
The physio's gave me some excercises but they never helped, it took a long time to find the cause.
Yes Please !
the weight of the barbells would be pretty close, probably not to the gram though. however I know I could make them for a lot less than $3.00 per kilo.
are you looking at making barbells or plates?
as for plans..
http://startingstrength.com/files/starting_strength_rack.pdf
I'm sure that has all the info you need.
in the end it will look like this.
http://startingstrength.com/index.php/site/equipment
Wear em loud and proud eh?
Nah, I hate that carpet burnish feeling I get from scraping the bar up against my shin. I still get it a bit in trackies, but it's not as bad. Hopefully my shin skin will start getting thicker soon.
Are people doing deadlifts on leg day or back day?
I always seem to do them on back day purely because I like to squat on leg day and I wouldn't be able to get the most out of it if I did them on the same day. I do Bulgarian/straight leg deadlifts on leg day instead which seem to be ok even after squatting.
Edited by Mitcho_7
Are you guys more oriented toward the powerlifting side of training?
I just find I struggle to get decent weight up on deadlifts after doing 4x10 of squats. Doing them on my back day seems to work better for me I think. It allows me to give them my all rather than half assing them because I'm already spent.
I was just interested to hear other people's thoughts on how you work them both into your training...
Edited by Mitcho_7
Having watched some tutorial/classroom style videos from Mark Rippetoe over the last week, I'm convinced that deadlifts are primarily a back exercise (while they do hammer glutes and hammies something nasty though)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
