barbell and dumbell are two different things though.
I can lift heaps more (not that its much) on barbell then what I can with dumbells.
stabaliser muscles all come into effect with DBs and one arm can compensate for the other (to some degree) with BB. I also find that I go a lot lower with DBs then I do with a bar
That you can barbell flat bench 100kg or more for reps
Fair enough, easy assumption to make then. There's a few factors that contribute to it being "low".
For starters, unless I'm mistaken your flat bench should always be higher than your incline. The 35s are max weight sets, so they are done after 2 sets of 30s, after 2 sets of 25s...and after 6 sets of flat bench...which all leaves me pretty wrecked by the time I get to them! I've never tried incline dumbells fresh, they are a supplementary exercise for me, so the numbers aren't too important for me to compare. I also started flat benching long before incline, so flat bench has had a lot more time to gradually step up :)
Sort of related:
Was flat benching lastnight and I always like to push it (pun) until I can do no more...this can mean 10 long seconds to get the bar up on the last rep...during which time other people helpfully/annoyingly come over and go to grab the bar, thinking I'm about to drop it lol. It's nice that they have your back, but when you're putting everything you have into it, it's extremely difficult to talk and politely tell them "don't touch the f**king bar!".
Good answer Birds, what weight we lift on assistance exercises is not important, far too many factors, as you pointed out
Its like some dick telling us how much he curls, irrelevant
Again, a case of majoring in the minor shit
Not one of my lifters has ever maxed an assistance exercises before doing the main lift. Even our 250-300kg box squats are done AFTER squatting
Sort of related:
I've always been under the impression that you should stop 1 before you max out to failure.
In saying that, if your form is the same as the first one guess you're not failing.
See, we're not so different afterall :P
What are the benefits of box squats after squats, as an assistance exercise?
With different size boxes we can target the lifters weakest part of the lift, where his leverage cant overcome the weight, everyone has this point on every lift, others we would never fail lol
We also do pause squats to teach confidence in the hole, and finish with BB lunges, maybe GHR afterwards
I can't bench much more with the bar than with dumbells. On incline I can probably do more with dumbells actually. I think tha is purely because I have just always used dumbells because it was slightly safer when training alone.
I do incline bench first and then flat bench, because my upper chest was lagging a bit...
Mitch, can you do me a favour mate, can you please post up an Anatomy chart and show me the upper chest
I've looked long and hard, cant find one.
Check where the pec insertion points are, the entire muscle contracts
Its a bodybuilding myth, you cant alter the shape of your muscles, and if it doesnt exist on an anatomy chart, it doesnt exist, unlike the different heads for deltoids, which are on the chart and do exist
Just sayin
I no I'm the Lone Ranger on here, but the truth is the truth
Look again?
The pec has two heads. Sternal and clavicular, named after where they originate from. Sure they share a common tendon and both heads will contract in flat bench and incline. But in incline bench the emphasis is placed more on the clavicular head due to position on the arm in relation to the torso.
Just because two seperate heads of a muscle share a common tendon doesn't mean the same movement will impact both heads equally. Take you deltoid example. 3 heads originating from slightly different spots and all insert at the same point on the humerus. So why doesn't overhead press give you big rear delts? Because of the position of the arm in relation to the torso. Sure the rear delts will still contract in overhead press but not to the same degree that they do in reverse flyes or barbell rows and that's why they don't get big doing only overhead press.
I wasn't suggesting I can alter the shape of my clavicular pectoral head, I was saying I wanted to stimulate growth in it more than my sternal head to even them up. Which is why I changed to doing incline first, where I can lift a bigger weight for more rels and recruit more motor units in the clavicular head than I would doing it afterwards in a fatigued state. Which hopefully helps stimulate hypertrophy in the clavicular head.
Sorry if I was unclear with my statement.
Edited by Mitcho_7
Any decent anatomy book will clearly label the clavicular pectoral head.
But i get the feeling you are just nit-picking at the fact I called it "upper chest" instead of specifically referring to the clavicular pectoral head. In which case, chill out and excuse me for being a bit lax with anatomical terms on a forum. Even my anatomy professor has called it the upper chest.
If you are saying there isn't actually a clavicular pectoral head then that's more of a worry.
Edited by Mitcho_7
Mitch, all I'm saying is for years people think that by changing an angle or a grip they are hitting a different muscle etc, like guys that do preacher curls for lower biceps and concentration curls for the peak
They are trying to train muscles that dont exist, just like the upper pecs
Do incline presses, my guys do them every single bench session because they are an awesome exercise, not because they are hitting a fantasy muscle
We love the training effect we get out of them.
Our "upper" pecs are no more developed than anyone that doesnt do them
ps What did your anatomy professor press?
Edited by markos
A variety of resistance exercises can be used to train the pectoralis major, including bench pressing (using dumbbells, barbells or machines at various angles such as decline, incline and flat where the hips are above, below and level with the head respectively), push ups, flyes (using dumbbells or machines at either flat or inclined angles), cable crossovers or dips. This muscle is often said to consist of four portions (upper, lower, inner and outer) but the pectoralis actually contracts evenly across all heads during most exercises and as such no portion can be 'targeted'
I f**king hate having to go look for references on a topic I know through 30 years of lifting and training people. And I didnt need a proffesor to tell me.
Anyone thats ever lifted would know this if he paid attention, rather than read it in a book
I'm not saying your not correct because you have probably forgotten more than I know about strength training.
However, until you send me a link/point me in the direction of a reference that is valid, which shows that, then I'm inclined to remain skeptical.
At the risk of sparking another debate...
Stepped up the behind neck military press tonight. Usually do 45kg x 10 x 3 and 50kg x 10 x 3. Now onto 50kg x 10 x 6. Interestingly, the last 3 sets felt easier than they did when I was doing 45kg for the first 3 sets (mind trick because I'm starting off with max weight?), despite wrecking myself more by the end of it.
The next increase will be 55kg for the last 3 sets. Don't know what I'm shooting for here...I think it would be cool to eventually do bodyweight (79kg) for reps - I'm a while off that though.
Should probably start a build thread instead of spamming this one with changes to my workout :)
Related: discovering the beauty of 1.25kg plates for incremental increases on deadlifts and squats. Only just notice the difference in weight, but it's so negligible, you can still push out the same reps. Can only imagine 750gm plates would be even better!
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
