the possible Issue with mixed grip (rare) is a torn bicep.
Having that hand turned out puts the bicep in a kind of flexed position.
Gotta be careful not to bend the arms when doing deads (some people have a habbit close to lockout on really heavy weights to flex that arm a little)
It's a common injury in Strongman comps during the tyre flip events.
as you grab the tyre with both hands, palms up and lift to get it off the ground.
mixed grip has nothing to do with shoulders.
Using straps will probably help you lift more weight, but it just masks a weakness.
masking a weakness leads to injury
It's not that I have trouble with grip it's more the fact I have no powder and there is none at gym and over 100kg hurts the callus on the hands.
who uses powder? :/
your deadlift is improving Troy :D
who uses powder? :/
haha, I should add I haven't managed to lift 170kg by the way!! Most I've locked out is 165kg. Have recently reset weight and doing 4 sets of 5 reps. Currently on 135kg, stepping up 2.5kg each session.
lol riiiiiggghhhhttttt... a freind gave me a big bag of chalk once... never used it
He means Chalk.
and all the cool people use chalk.
Yup and thanks, the voice of reason.
This is true lol.
Gonna go back to a simplified routine as well for a little while, just don't have patience to deal with 5 different exercises per session now that the gym is full of new-year resolution clowns.
Squats, deadlifts, bench press, OHP, pull ups.
Shoulder injury currently.
When I'm fine I'd do 3 sets on wednesday
so it would go
Bench, Rows, OHP, chins
My shoulder injury is due to a lot of things, but a major one is more pressing then pulling.
so now on the mend, I just do bench, then lots of pulling..
I'll add them back in later.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
