I have an extremely high tolerance to pre-workouts or in general...stimulants etc.
I tried Craze for a while but needed 4-5 scoops to really feel it. This is coming from someone who was using 200mcg of clenbuterol each day and eventually became completely immune to it as well as DMAA. So instead I simply finish work, train than eat some good solid carbs and protein. For almost 2 months I haven't had any supplements whatsoever. Old school is the way to go :)
you've definitely changed your opinion then...
Here is a thought to consider. I make some assumptions here so take from it what you will.
How much do you rely on the stimulant pre-workout to give your best effort in physical performance?
If you are saying you don't do as well without one, then you are likely not even close to your limit.
Not trying to sound too harsh here but, It's a mental crutch. You are waiting for some kind of buzz to tell you it's now ok to pick up a weight.
You are the one lifting the weights when you are taking it, not the suppliment. Once you realise that ,you can pocket the money and buy some beer on the weekend with it.
Funnily, we're talking about PWO supps being a waste of money with regards to fitness....so instead you suggest the consumption of alcohol? hahaha :P
Good point. They are both un-related to fitness, except one pretends to be and isn't.
Edited by rev210
Didn't know clen had a pre-workout type effect?
Used wraps for the first time since August last year for squats...
man.. don't miss that pain.
and that was with half arsed wrapping.
good rebound though.
and the tightness gives a nice secure feeling when you look past the burning pain on the back of the knee.. lol
Never if you don't need to.
I've only done a best of 150kg for 3 sets of 5 squats without wraps.
Program had me doing 145 last week and 152.5 this week
so I started using them this week and will keep doing so till the comp in April.
I think you get used to them after a while... just like your hands get used to deadlifts.
I've seen blood on some peoples legs before and lots of bruises.
I had Scott at PTC Brisbane wrap me once leading up to last years Nats.
he goes, how tight do you want them?
I told him to go easy first time since I'm used to wrapping myself.
He goes ok I'll go about 50%
This 50% managed to get 2 extra loops around the knee then when I wrap "tight" at home myself..... It hurt like hell.. lol
And my wraps are the 2 meter ones which are well used Inzer ones.... compared to the 2.5 others use.
Hopefully I'll better my last PB at a slightly lighter bodyweight come April.
Going back on SS until I hit 180kg dl, 140kg squat, 100kg bench. Didn't feel like I was getting anywhere on the other program I was on, progression felt too slow.
I have been on the same program for about a month now, lifts have improved but my biggest issue is the gyms weight. I have to go up with 2.5kg increments rather then the 1.25 that is suggested.
Have plateaued on bench already at 60kg which I am trying to get past. Always sucked at bench for some reason, always get to 60kg and struggle to go up any further.
Weak shoulder girdle muscles is the reason. I can tell you that a good way (other ways get there too) to get your bench max up is the following ;
a) stop doing bench press
b) Start doing work on your shoulder,.scapular and rotator cuff strength and flexibillity.
c) Gradually incorporate strict press movements
d) when you can do your bodyweight on a strict press then you can think about bench press.
e) You are only allowed to 'think' about bench press until someone shows you how to do them properly, then you can 'do' them.
Do something like this and that plateu is going to be history. Also you are going to have much better muscle balance and less risk of injury as the weight goes up.
Edited by rev210
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
