Bench was going great tonight; best weights I've pressed in weeks and all nice and low to the chest. Last set was 2 reps of 107.5kg. No shoulder pains. Then did close grip lat pulldown. Still all good. Then warm up on 60kg incline press and...f**k...my shoulder cracked the shits. Felt like I dislocated it or something. Couldn't even finish the set. Now can't move arm in certain ways (specifically above my neck and across my body) without it hurting.
Gonna book for scans tomorrow; looks like I'm deadlifting and squatting indefinitely.
That sucks.
Is it a pinching type of pain? Does it 'pop' when you move it high or across?
Yes it's pinching and if I can stand the pain of moving my arm high it does pop eventually. Can't even take my farkin T shirts off, it's ridiculous. Still can't believe a 60kg incline press did this...
Doc pressed on a few places and seems to think inflammation of the supraspinatus/bursa; prescribed anti-inflams. I reckon it's a tear/rupture though, so I insisted on an ultrasound referral. See what the imaging reveals I guess.
FML
FML
Sucks :(
Hopefully ultrasound will give you more information and you can get it sorted.
but your life isn't that bad
FML
should of insisted on an MRI referral.
Ultra sound will only show youve got an injury/fluid.
MRI will actually show length, extent of injury etc.
MRI will also set him back a shitload of money. Prior to healthcare reimbursements (which won't be much anyway), the MRI my mate got on his knee not too long ago here in ACT cost somewhere just over $500.
$500 is not a shitload of money when it comes to your health.
Most people wouldn't think twice about spending $500 on their car.....your body is with you for the rest of your life
Oh I'm not saying it isn't worth it; merely saying that perhaps jumping straight to an MRI isn't necessarily the way to do it. I'd go with the ultrasound first up as it's probably close enough to free for there to be no real reason NOT to bother, and then depending on the results of the ultrasound you could push for the MRI.
FML
With the shoulder it could be anything but it sounds similar to my injury which is bicep tendinitis - basically the tendon that runs from the bicep to the shoulder is enflamed and pinches and pops as it passes through the hole(?) causing the pain.
Physio, Voltaren, stretching and no chest work for 4-6 weeks cured it for me but then it came back again. And no overhead presses of any sort!
Good luck with whatever it is :)
    • On the hot side pipe work, or if you want to compensate for pressure loss from the IC, post intercooler on the cold side, pre-throttle
    • They're notoriously difficult if you traverse forums... the 102TB and FAST102 are so bad that most people actively don't buy it unless they REALLY want that extra 1hp. The idle stuff isn't really that hard. The cam is pretty manageable and while it acts like a larger cam the whole car actually drives smoother than before. I like to just tinker so if I can get 50rpm less variance or rule out situations where it does 'unexpected' things it's fun for me. HOWEVER If you just let a tuner give it a guess for a couple of hours and had no way/desire to test and tweak it yourself you'd spend a lot of money at the tuner or be pretty frustrated, that's for sure. But yeah. Drives great. (then I drive partner's Civic Type R and I think.. well, more tweaking to do) But for what it is (cam, TB, intake, manual etc) it does commute around really great once you figure out how the idle tables and GM's systems intend to work.
    • I usually source pressure on inlet manifold after throttle body
    • Where is the best location for boost pressure source when running mac 3port boost solenoid?  my new turbo does not have a fitting for that on the compressor housing.  how come Garrett make a turbo without that?  im confused
    • From my memory, which isn't that great, we did have issues getting the large throttle body on my old LS1 to play nicely at idle, first it would stall, then it would only idle at 2k rpm, then it would hang at 2k rpm for a few seconds and then drop and stall, then, finally, the best we got was it would hang at 1.5k rpm for a few seconds then drop to around 800 rpm The tuner stated that large cable throttle bodies are a PITA, and if I wanted anything better than what we ended up with I would need a electronic throttle body and all of the aftermarket ECU stuff to run it
