Bench was going great tonight; best weights I've pressed in weeks and all nice and low to the chest. Last set was 2 reps of 107.5kg. No shoulder pains. Then did close grip lat pulldown. Still all good. Then warm up on 60kg incline press and...f**k...my shoulder cracked the shits. Felt like I dislocated it or something. Couldn't even finish the set. Now can't move arm in certain ways (specifically above my neck and across my body) without it hurting.
Gonna book for scans tomorrow; looks like I'm deadlifting and squatting indefinitely.
That sucks.
Is it a pinching type of pain? Does it 'pop' when you move it high or across?
Yes it's pinching and if I can stand the pain of moving my arm high it does pop eventually. Can't even take my farkin T shirts off, it's ridiculous. Still can't believe a 60kg incline press did this...
Doc pressed on a few places and seems to think inflammation of the supraspinatus/bursa; prescribed anti-inflams. I reckon it's a tear/rupture though, so I insisted on an ultrasound referral. See what the imaging reveals I guess.
FML
FML
Sucks :(
Hopefully ultrasound will give you more information and you can get it sorted.
but your life isn't that bad
FML
should of insisted on an MRI referral.
Ultra sound will only show youve got an injury/fluid.
MRI will actually show length, extent of injury etc.
MRI will also set him back a shitload of money. Prior to healthcare reimbursements (which won't be much anyway), the MRI my mate got on his knee not too long ago here in ACT cost somewhere just over $500.
$500 is not a shitload of money when it comes to your health.
Most people wouldn't think twice about spending $500 on their car.....your body is with you for the rest of your life
Oh I'm not saying it isn't worth it; merely saying that perhaps jumping straight to an MRI isn't necessarily the way to do it. I'd go with the ultrasound first up as it's probably close enough to free for there to be no real reason NOT to bother, and then depending on the results of the ultrasound you could push for the MRI.
FML
With the shoulder it could be anything but it sounds similar to my injury which is bicep tendinitis - basically the tendon that runs from the bicep to the shoulder is enflamed and pinches and pops as it passes through the hole(?) causing the pain.
Physio, Voltaren, stretching and no chest work for 4-6 weeks cured it for me but then it came back again. And no overhead presses of any sort!
Good luck with whatever it is :)
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
